Home » Eclipse Projects » Eclipse Platform » I core dump on CVS import, ?? gtk_progress_bar ...
I core dump on CVS import, ?? gtk_progress_bar ... [message #163428] Fri, 28 November 2003 20:18 Go to next message
--------------040903090702030107040300
Content-Type: text/plain; charset=us-ascii; format=flowed
Was I supposed to build Eclipse as build -os linux -ws gtk when I have
RedHat 9? I can command line (same user) cvs functions. I can checkout
a project into Eclipse that I created on the side. But, I core dump
Eclipse when I import using Team , Share Project. Here's the log. Any
suggestions are welcome.
name="hs_err_pid3748.log"
Content-Disposition: inline;
filename="hs_err_pid3748.log"
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4DB59F15
Function=(null)+0x4DB59F15
Library=/usr/lib/libgdk-x11-2.0.so.0
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.gtk.OS.gtk_progress_bar_set_fractio n(Native Method)
- locked <0x48b491e8> (a java.lang.Class)
at org.eclipse.swt.widgets.ProgressBar.updateBar(ProgressBar.ja va:213)
at org.eclipse.swt.widgets.ProgressBar.setSelection(ProgressBar .java:203)
at org.eclipse.jface.dialogs.ProgressIndicator.worked(ProgressI ndicator.java:115)
at org.eclipse.jface.wizard.ProgressMonitorPart.internalWorked( ProgressMonitorPart.java:156)
at org.eclipse.jface.operation.AccumulatingProgressMonitor$Coll ector.run(AccumulatingProgressMonitor.java:74)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
- locked <0x4486b308> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1614)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1432)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:136)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:261)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 758)
at org.eclipse.team.internal.ccvs.ui.wizards.SharingWizard.perf ormFinish(SharingWizard.java:174)
at org.eclipse.team.internal.ui.ConfigureProjectWizard.performF inish(ConfigureProjectWizard.java:124)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:608)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:321)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:423)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:913)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1637)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1429)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
at org.eclipse.team.internal.ui.actions.ConfigureProjectAction$ 1.run(ConfigureProjectAction.java:42)
at org.eclipse.team.internal.ui.actions.TeamAction$1.run(TeamAc tion.java:168)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.team.internal.ui.actions.TeamAction.run(TeamActi on.java:165)
at org.eclipse.team.internal.ui.actions.ConfigureProjectAction. run(ConfigureProjectAction.java:35)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:71)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
at org.eclipse.jface.action.ActionContributionItem.access$000(A ctionContributionItem.java:44)
at org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:02 573986 /usr/java/j2sdk1.4.2_02/bin/java
0804e000-0804f000 rw-p 00005000 03:02 573986 /usr/java/j2sdk1.4.2_02/bin/java
40000000-40015000 r-xp 00000000 03:02 507918 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:02 507918 /lib/ld-2.3.2.so
40017000-4001f000 r-xp 00000000 03:02 672290 /usr/java/j2sdk1.4.2_02/jre/lib/i386/native_threads/libhpi.s o
4001f000-40020000 rw-p 00007000 03:02 672290 /usr/java/j2sdk1.4.2_02/jre/lib/i386/native_threads/libhpi.s o
40020000-40024000 rw-s 00000000 03:02 803465 /tmp/hsperfdata_piratepete/3748
40024000-40025000 r--s 00000000 03:02 770518 /usr/local/eclipse/plugins/org.eclipse.ui/ui.jar
40025000-4002f000 r-xp 00000000 03:02 2310162 /lib/tls/libpthread-0.29.so
4002f000-40030000 rw-p 0000a000 03:02 2310162 /lib/tls/libpthread-0.29.so
40032000-40034000 r-xp 00000000 03:02 507929 /lib/libdl-2.3.2.so
40034000-40035000 rw-p 00002000 03:02 507929 /lib/libdl-2.3.2.so
40036000-40430000 r-xp 00000000 03:02 2310502 /usr/java/j2sdk1.4.2_02/jre/lib/i386/client/libjvm.so
40430000-4044c000 rw-p 003f9000 03:02 2310502 /usr/java/j2sdk1.4.2_02/jre/lib/i386/client/libjvm.so
4045e000-40470000 r-xp 00000000 03:02 507933 /lib/libnsl-2.3.2.so
40470000-40471000 rw-p 00011000 03:02 507933 /lib/libnsl-2.3.2.so
40473000-40494000 r-xp 00000000 03:02 2310160 /lib/tls/libm-2.3.2.so
40494000-40495000 rw-p 00020000 03:02 2310160 /lib/tls/libm-2.3.2.so
40495000-40498000 r--s 00000000 03:02 1229326 /usr/java/j2sdk1.4.2_02/jre/lib/ext/dnsns.jar
40498000-4049d000 r--s 00000000 03:02 2458339 /usr/local/eclipse/startup.jar
4049d000-4049e000 r-xp 00000000 03:02 1933740 /usr/local/eclipse/plugins/org.eclipse.core.resources.linux/ os/linux/x86/libcore_2_1_0a.so
4049e000-4049f000 rw-p 00001000 03:02 1933740 /usr/local/eclipse/plugins/org.eclipse.core.resources.linux/ os/linux/x86/libcore_2_1_0a.so
4049f000-404a2000 r-xp 00000000 03:02 360485 /usr/lib/libgmodule-2.0.so.0.200.1
404a2000-404a3000 rw-p 00002000 03:02 360485 /usr/lib/libgmodule-2.0.so.0.200.1
404a3000-404ae000 r-xp 00000000 03:02 507939 /lib/libnss_files-2.3.2.so
404ae000-404af000 rw-p 0000a000 03:02 507939 /lib/libnss_files-2.3.2.so
404af000-404bf000 r-xp 00000000 03:02 1655137 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libverify.so
404bf000-404c1000 rw-p 0000f000 03:02 1655137 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libverify.so
404c1000-404e1000 r-xp 00000000 03:02 1655123 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libjava.so
404e1000-404e3000 rw-p 0001f000 03:02 1655123 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libjava.so
404e3000-404f7000 r-xp 00000000 03:02 1655138 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libzip.so
404f7000-404fa000 rw-p 00013000 03:02 1655138 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libzip.so
404fa000-41e92000 r--s 00000000 03:02 2523387 /usr/java/j2sdk1.4.2_02/jre/lib/rt.jar
41edc000-41ef2000 r--s 00000000 03:02 2523386 /usr/java/j2sdk1.4.2_02/jre/lib/sunrsasign.jar
41ef2000-41fcd000 r--s 00000000 03:02 2523385 /usr/java/j2sdk1.4.2_02/jre/lib/jsse.jar
41fcd000-41fde000 r--s 00000000 03:02 2523377 /usr/java/j2sdk1.4.2_02/jre/lib/jce.jar
41ffc000-41fff000 r-xp 00000000 03:02 524432 /usr/X11R6/lib/libXrandr.so.2.0
41fff000-42000000 rw-p 00002000 03:02 524432 /usr/X11R6/lib/libXrandr.so.2.0
42000000-4212e000 r-xp 00000000 03:02 2310158 /lib/tls/libc-2.3.2.so
4212e000-42131000 rw-p 0012e000 03:02 2310158 /lib/tls/libc-2.3.2.so
42133000-4268c000 r--s 00000000 03:02 2523378 /usr/java/j2sdk1.4.2_02/jre/lib/charsets.jar
44734000-4473b000 r--s 00000000 03:02 2654633 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/ws/gtk/swt-pi .jar
4473b000-4473f000 r-xp 00000000 03:02 360489 /usr/lib/libgthread-2.0.so.0.200.1
4473f000-44740000 rw-p 00003000 03:02 360489 /usr/lib/libgthread-2.0.so.0.200.1
4c922000-4cb22000 r--p 00000000 03:02 475155 /usr/lib/locale/locale-archive
4cd22000-4cd2f000 r--s 00000000 03:02 1229327 /usr/java/j2sdk1.4.2_02/jre/lib/ext/ldapsec.jar
4cd2f000-4cdeb000 r--s 00000000 03:02 1229330 /usr/java/j2sdk1.4.2_02/jre/lib/ext/localedata.jar
4cdeb000-4ce07000 r--s 00000000 03:02 1229329 /usr/java/j2sdk1.4.2_02/jre/lib/ext/sunjce_provider.jar
4ce87000-4ce9f000 r--s 00000000 03:02 1835635 /usr/local/eclipse/plugins/org.eclipse.core.boot/boot.jar
4ce9f000-4ced4000 r--s 00000000 03:02 115258 /usr/local/eclipse/plugins/org.eclipse.core.runtime/runtime. jar
4ced4000-4cf23000 r--s 00000000 03:02 1540574 /usr/local/eclipse/plugins/org.eclipse.ui.views/views.jar
4cf23000-4d137000 r--s 00000000 03:02 2048650 /usr/local/eclipse/plugins/org.eclipse.ui.workbench/workbenc h.jar
4d137000-4d1a3000 r--s 00000000 03:02 2261545 /usr/local/eclipse/plugins/org.eclipse.jface/jface.jar
4d1a3000-4d230000 r--s 00000000 03:02 164492 /usr/local/eclipse/plugins/org.eclipse.core.resources/resour ces.jar
4d230000-4d246000 r--s 00000000 03:02 1589432 /usr/local/eclipse/plugins/org.apache.xerces/xmlParserAPIs.j ar
4d246000-4d365000 r--s 00000000 03:02 1589437 /usr/local/eclipse/plugins/org.apache.xerces/xercesImpl.jar
4d365000-4d3cc000 r--s 00000000 03:02 2900598 /usr/local/eclipse/plugins/org.eclipse.team.cvs.core/cvs.jar
4d3cc000-4d3ff000 r--s 00000000 03:02 1737205 /usr/local/eclipse/plugins/org.eclipse.search/search.jar
4d3ff000-4d40d000 r--s 00000000 03:02 770519 /usr/local/eclipse/plugins/org.eclipse.pde/pde.jar
4d40d000-4d658000 r--s 00000000 03:02 2654635 /usr/local/eclipse/plugins/org.eclipse.jdt.core/jdtcore.jar
4d658000-4d698000 r--s 00000000 03:02 2720299 /usr/local/eclipse/plugins/org.eclipse.jdt.junit/junitsuppor t.jar
4d698000-4d6ae000 r--s 00000000 03:02 262758 /usr/local/eclipse/plugins/org.eclipse.help.ui/helpworkbench .jar
4d6ae000-4d70f000 r--s 00000000 03:02 2949755 /usr/local/eclipse/plugins/org.eclipse.compare/compare.jar
4d78f000-4d83e000 r--s 00000000 03:02 2654631 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/ws/gtk/swt.ja r
4d83e000-4d868000 r-xp 00000000 03:02 1114363 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/os/linux/x86/ libswt-pi-gtk-2133.so
4d868000-4d86a000 rw-p 00029000 03:02 1114363 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/os/linux/x86/ libswt-pi-gtk-2133.so
4d86a000-4d870000 r--s 00000000 03:02 2064587 /usr/lib/gconv/gconv-modules.cache
4d870000-4d871000 r-xp 00000000 03:02 1130550 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
4d871000-4d872000 rw-p 00000000 03:02 1130550 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
4d872000-4d873000 r-xp 00000000 03:02 2064531 /usr/lib/gconv/ISO8859-1.so
4d873000-4d874000 rw-p 00001000 03:02 2064531 /usr/lib/gconv/ISO8859-1.so
4d875000-4d877000 r-xp 00000000 03:02 3063914 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4d877000-4d878000 rw-p 00001000 03:02 3063914 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4d878000-4d8e1000 r-xp 00000000 03:02 360483 /usr/lib/libglib-2.0.so.0.200.1
4d8e1000-4d8e2000 rw-p 00069000 03:02 360483 /usr/lib/libglib-2.0.so.0.200.1
4d8e2000-4db2b000 r-xp 00000000 03:02 360706 /usr/lib/libgtk-x11-2.0.so.0.200.1
4db2b000-4db34000 rw-p 00248000 03:02 360706 /usr/lib/libgtk-x11-2.0.so.0.200.1
4db36000-4db9f000 r-xp 00000000 03:02 360700 /usr/lib/libgdk-x11-2.0.so.0.200.1
4db9f000-4dba4000 rw-p 00069000 03:02 360700 /usr/lib/libgdk-x11-2.0.so.0.200.1
4dba4000-4dbbb000 r-xp 00000000 03:02 360664 /usr/lib/libatk-1.0.so.0.200.0
4dbbb000-4dbbd000 rw-p 00016000 03:02 360664 /usr/lib/libatk-1.0.so.0.200.0
4dbbd000-4dbcf000 r-xp 00000000 03:02 360702 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
4dbcf000-4dbd0000 rw-p 00011000 03:02 360702 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
4dbd0000-4dbdc000 r-xp 00000000 03:02 360696 /usr/lib/libpangox-1.0.so.0.200.1
4dbdc000-4dbdd000 rw-p 0000b000 03:02 360696 /usr/lib/libpangox-1.0.so.0.200.1
4dbdd000-4dc04000 r-xp 00000000 03:02 360692 /usr/lib/libpango-1.0.so.0.200.1
4dc04000-4dc10000 rw-p 00026000 03:02 360692 /usr/lib/libpango-1.0.so.0.200.1
4dc10000-4dc43000 r-xp 00000000 03:02 360487 /usr/lib/libgobject-2.0.so.0.200.1
4dc43000-4dc45000 rw-p 00032000 03:02 360487 /usr/lib/libgobject-2.0.so.0.200.1
4dc45000-4dc65000 r-xp 00000000 03:02 360698 /usr/lib/libpangoxft-1.0.so.0.200.1
4dc65000-4dc66000 rw-p 0001f000 03:02 360698 /usr/lib/libpangoxft-1.0.so.0.200.1
4dc66000-4dc6d000 r-xp 00000000 03:02 524422 /usr/X11R6/lib/libXi.so.6.0
4dc6d000-4dc6e000 rw-p 00006000 03:02 524422 /usr/X11R6/lib/libXi.so.6.0
4dc6e000-4dc7b000 r-xp 00000000 03:02 524414 /usr/X11R6/lib/libXext.so.6.4
4dc7b000-4dc7c000 rw-p 0000c000 03:02 524414 /usr/X11R6/lib/libXext.so.6.4
4dc7c000-4dc8d000 r-xp 00000000 03:02 524420 /usr/X11R6/lib/libXft.so.2.1
4dc8d000-4dc8e000 rw-p 00010000 03:02 524420 /usr/X11R6/lib/libXft.so.2.1
4dc8e000-4dc95000 r-xp 00000000 03:02 524434 /usr/X11R6/lib/libXrender.so.1.2
4dc95000-4dc96000 rw-p 00006000 03:02 524434 /usr/X11R6/lib/libXrender.so.1.2
4dc96000-4dcb7000 r-xp 00000000 03:02 360601 /usr/lib/libfontconfig.so.1.0
4dcb7000-4dcba000 rw-p 00021000 03:02 360601 /usr/lib/libfontconfig.so.1.0
4dcbb000-4dd97000 r-xp 00000000 03:02 524404 /usr/X11R6/lib/libX11.so.6.2
4dd97000-4dd9a000 rw-p 000db000 03:02 524404 /usr/X11R6/lib/libX11.so.6.2
4dd9a000-4dde6000 r-xp 00000000 03:02 360597 /usr/lib/libfreetype.so.6.3.2
4dde6000-4ddea000 rw-p 0004c000 03:02 360597 /usr/lib/libfreetype.so.6.3.2
4ddeb000-4de09000 r-xp 00000000 03:02 360473 /usr/lib/libexpat.so.0.4.0
4de09000-4de0b000 rw-p 0001e000 03:02 360473 /usr/lib/libexpat.so.0.4.0
4de0b000-4de30000 r-xp 00000000 03:02 1114364 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/os/linux/x86/ libswt-gtk-2133.so
4de30000-4de32000 rw-p 00025000 03:02 1114364 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/os/linux/x86/ libswt-gtk-2133.so
4de32000-4de3e000 r-xp 00000000 03:02 2539689 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
4de3e000-4de3f000 rw-p 0000b000 03:02 2539689 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
4de3f000-4de44000 r--s 00000000 03:02 2933139 /usr/local/eclipse/plugins/org.eclipse.platform/startup.jar
4de44000-4de4c000 r--s 00000000 03:02 1540575 /usr/local/eclipse/plugins/org.eclipse.team.webdav/webdavpro vider.jar
4de4d000-4de55000 r-xp 00000000 03:02 524412 /usr/X11R6/lib/libXcursor.so.1.0
4de55000-4de56000 rw-p 00007000 03:02 524412 /usr/X11R6/lib/libXcursor.so.1.0
4de56000-4dea8000 r--s 00000000 03:02 2851273 /usr/local/eclipse/plugins/org.eclipse.update.core/updatecor e.jar
4dea8000-4ded4000 r--s 00000000 03:02 2228725 /usr/local/eclipse/plugins/org.eclipse.help/help.jar
4ded4000-4df2a000 r--s 00000000 03:02 1065589 /usr/local/eclipse/plugins/org.eclipse.jface.text/jfacetext. jar
4df2a000-4df3c000 r--s 00000000 03:02 1704434 /usr/local/eclipse/plugins/org.eclipse.text/text.jar
4df3c000-4dfb5000 r--s 00000000 03:02 1507961 /usr/local/eclipse/plugins/org.eclipse.debug.ui/dtui.jar
4dfb5000-4e383000 r--s 00000000 03:02 410184 /usr/local/eclipse/plugins/org.eclipse.jdt.ui/jdt.jar
4e383000-4e451000 r--s 00000000 03:02 2228726 /usr/local/eclipse/plugins/org.eclipse.team.cvs.ui/teamcvsui .jar
4e451000-4e5db000 r--s 00000000 03:02 2802185 /usr/local/eclipse/plugins/org.eclipse.pde.ui/pdeui.jar
4e5db000-4e675000 r--s 00000000 03:02 1639015 /usr/local/eclipse/plugins/org.eclipse.update.ui/updateui.ja r
4e675000-4e733000 r--s 00000000 03:02 737911 /usr/local/eclipse/plugins/org.eclipse.jdt.debug.ui/jdiui.ja r
4e733000-4e7fe000 r--s 00000000 03:02 2654634 /usr/local/eclipse/plugins/org.eclipse.ui.externaltools/exte rnaltools.jar
4e7fe000-4e837000 r--s 00000000 03:02 131692 /usr/local/eclipse/plugins/org.eclipse.ui.workbench.textedit or/texteditor.jar
4e837000-4e849000 r--p 00000000 03:02 82116 /usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
4e849000-4e859000 r--s 00000000 03:02 803446 /usr/local/eclipse/plugins/org.eclipse.pde.runtime/pdert.jar
4e859000-4e89f000 r--s 00000000 03:02 1917561 /usr/local/eclipse/plugins/org.eclipse.team.ui/teamui.jar
4e89f000-4e8b6000 r--s 00000000 03:02 426480 /usr/local/eclipse/plugins/org.eclipse.team.core/team.jar
4e8b6000-4e8d0000 r--s 00000000 03:02 131693 /usr/local/eclipse/plugins/org.eclipse.ui.editors/editors.ja r
4e8d0000-4e8db000 r--s 00000000 03:02 131691 /usr/local/eclipse/plugins/org.eclipse.team.cvs.ssh/teamcvss sh.jar
4e8db000-4e8ed000 r--p 00000000 03:02 82118 /usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
4e8ed000-4e90b000 r--s 00000000 03:02 3441285 /usr/local/eclipse/plugins/org.eclipse.debug.core/dtcore.jar
4e98b000-4e992000 r--s 00000000 03:02 49655 /usr/local/eclipse/plugins/org.eclipse.ant.core/antsupport.j ar
4ea12000-4ea72000 r--s 00000000 03:02 197261 /usr/local/eclipse/plugins/org.eclipse.pde.core/pdecore.jar
4ea72000-4ea96000 r--s 00000000 03:02 1901173 /usr/local/eclipse/plugins/org.eclipse.jdt.launching/launchi ng.jar
4ea96000-4eaa2000 r--s 00000000 03:02 327800 /usr/local/eclipse/plugins/org.eclipse.jdt.debug/jdi.jar
4eaa2000-4eb42000 r--s 00000000 03:02 327801 /usr/local/eclipse/plugins/org.eclipse.jdt.debug/jdimodel.ja r
4eb42000-4ebf5000 r--s 00000000 03:02 754168 /usr/local/eclipse/plugins/org.apache.ant/ant.jar
4ebf5000-4ec99000 r--s 00000000 03:02 754166 /usr/local/eclipse/plugins/org.apache.ant/optional.jar
4ec99000-4ecac000 r--s 00000000 03:02 885185 /usr/local/eclipse/plugins/org.eclipse.team.ftp/ftp.jar
4ecac000-4ecba000 r--s 00000000 03:02 82381 /usr/local/eclipse/plugins/org.eclipse.pde.build/pdebuild.ja r
4ecba000-4ecdf000 r--s 00000000 03:02 2802184 /usr/local/eclipse/plugins/org.eclipse.update.ui.forms/forms .jar
4ed5f000-4ed6f000 r-xp 00000000 03:02 1655134 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libnet.so
4ed6f000-4ed70000 rw-p 0000f000 03:02 1655134 /usr/java/j2sdk1.4.2_02/jre/lib/i386/libnet.so
4ed70000-4ed71000 r-xp 00000000 03:02 1114362 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/os/linux/x86/ libswt-gnome-gtk-2133.so
4ed71000-4ed72000 rw-p 00001000 03:02 1114362 /usr/local/eclipse/plugins/org.eclipse.swt.gtk/os/linux/x86/ libswt-gnome-gtk-2133.so
4ed72000-4ed79000 r-xp 00000000 03:02 360682 /usr/lib/liblinc.so.1.0.0
4ed79000-4ed7a000 rw-p 00006000 03:02 360682 /usr/lib/liblinc.so.1.0.0
4ed7a000-4ed7b000 r-xp 00000000 03:02 475169 /usr/kerberos/lib/libcom_err.so.3.0
4ed7b000-4ed7c000 rw-p 00001000 03:02 475169 /usr/kerberos/lib/libcom_err.so.3.0
4ed7e000-4ed81000 r-xp 00000000 03:02 507937 /lib/libnss_dns-2.3.2.so
4ed81000-4ed82000 rw-p 00003000 03:02 507937 /lib/libnss_dns-2.3.2.so
4ed82000-4ed91000 r-xp 00000000 03:02 507949 /lib/libresolv-2.3.2.so
4ed91000-4ed92000 rw-p 0000f000 03:02 507949 /lib/libresolv-2.3.2.so
4ee22000-4ee59000 r-xp 00000000 03:02 360710 /usr/lib/libgnomevfs-2.so.0.0.0
4ee59000-4ee5b000 rw-p 00036000 03:02 360710 /usr/lib/libgnomevfs-2.so.0.0.0
4ee5b000-4ee6c000 r-xp 00000000 03:02 360688 /usr/lib/libbonobo-activation.so.4.0.0
4ee6c000-4ee6e000 rw-p 00011000 03:02 360688 /usr/lib/libbonobo-activation.so.4.0.0
4ee6e000-4eea7000 r-xp 00000000 03:02 360684 /usr/lib/libORBit-2.so.0.0.0
4eea7000-4eeb0000 rw-p 00038000 03:02 360684 /usr/lib/libORBit-2.so.0.0.0
4eeb0000-4ef8f000 r-xp 00000000 03:02 360610 /usr/lib/libxml2.so.2.5.4
4ef8f000-4ef9a000 rw-p 000de000 03:02 360610 /usr/lib/libxml2.so.2.5.4
4ef9b000-4efa7000 r-xp 00000000 03:02 360517 /usr/lib/libz.so.1.1.4
4efa7000-4efa9000 rw-p 0000b000 03:02 360517 /usr/lib/libz.so.1.1.4
4efa9000-4efdc000 r-xp 00000000 03:02 360708 /usr/lib/libgconf-2.so.4.1.0
4efdc000-4efdf000 rw-p 00033000 03:02 360708 /usr/lib/libgconf-2.so.4.1.0
4efdf000-4f011000 r-xp 00000000 03:02 507982 /lib/libssl.so.0.9.7a
4f011000-4f014000 rw-p 00032000 03:02 507982 /lib/libssl.so.0.9.7a
4f014000-4f0f0000 r-xp 00000000 03:02 507981 /lib/libcrypto.so.0.9.7a
4f0f0000-4f102000 rw-p 000db000 03:02 507981 /lib/libcrypto.so.0.9.7a
4f105000-4f10b000 r-xp 00000000 03:02 507951 /lib/librt-2.3.2.so
4f10b000-4f10d000 rw-p 00005000 03:02 507951 /lib/librt-2.3.2.so
4f117000-4f11e000 r-xp 00000000 03:02 360500 /usr/lib/libpopt.so.0.0.0
4f11e000-4f11f000 rw-p 00006000 03:02 360500 /usr/lib/libpopt.so.0.0.0
4f11f000-4f131000 r-xp 00000000 03:02 475175 /usr/kerberos/lib/libgssapi_krb5.so.2.2
4f131000-4f132000 rw-p 00011000 03:02 475175 /usr/kerberos/lib/libgssapi_krb5.so.2.2
4f132000-4f18e000 r-xp 00000000 03:02 475189 /usr/kerberos/lib/libkrb5.so.3.1
4f18e000-4f190000 rw-p 0005c000 03:02 475189 /usr/kerberos/lib/libkrb5.so.3.1
4f190000-4f19f000 r-xp 00000000 03:02 475179 /usr/kerberos/lib/libk5crypto.so.3.0
4f19f000-4f1a0000 rw-p 0000f000 03:02 475179 /usr/kerberos/lib/libk5crypto.so.3.0
Heap at VM Abort:
Heap
def new generation total 1152K, used 84K [0x44740000, 0x44880000, 0x44c20000)
eden space 1024K, 1% used [0x44740000, 0x44743440, 0x44840000)
from space 128K, 55% used [0x44860000, 0x44871e48, 0x44880000)
to space 128K, 0% used [0x44840000, 0x44840000, 0x44860000)
tenured generation total 15180K, used 9106K [0x44c20000, 0x45af3000, 0x48740000)
the space 15180K, 59% used [0x44c20000, 0x45504ad0, 0x45504c00, 0x45af3000)
compacting perm gen total 16384K, used 16177K [0x48740000, 0x49740000, 0x4c740000)
the space 16384K, 98% used [0x48740000, 0x4970c7e0, 0x4970c800, 0x49740000)
Local Time = Fri Nov 28 20:06:17 2003
Elapsed Time = 214
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_02-b03 mixed mode)
--------------040903090702030107040300--
Re: I core dump on CVS import, ?? gtk_progress_bar ... [message #163871 is a reply to message #163428] Sun, 30 November 2003 23:54 Go to previous message
Originally posted by: akiezun.cuthis.mit.edu.andthis
please report bugs to bugzilla
this one should go to Platform SWT
a.
Previous Topic:Standard Push Button size
Next Topic:Editor for Non-file input
Current Time: Thu Nov 20 08:14:16 EST 2025
Powered by FUDForum. Page generated in 0.27126 seconds
