Home » Language IDEs » C / C++ IDE (CDT) » MBS: Options of Type "lib" don't work
MBS: Options of Type "lib" don't work [message #163024] Thu, 02 February 2006 08:53 Go to next message
I use a custom GNU Toolchain for embedded ARM development and made mysel=
f =
a build manifest for it.
My libraries which are defined with the "lib" valueType won't get passed=
to the commandline.
How does's CDT decides if a lib option has to be passed or not?
Simon Bitschnau
Re: MBS: Options of Type "lib" don't work [message #163114 is a reply to message #163024] Fri, 03 February 2006 09:31 Go to previous message
I found out that it's not the value type that is responsible for the =
problem. If I set it to StringList it gets ignored as well.
I don't used any applicabilityCalculator so it should always take part i=
n =
the build process. Am I missing something?
Simon
Am Thu, 02 Feb 2006 14:53:00 +0100 schrieb Simon Bitschnau =
<bahamut@simonb.at>:
> I use a custom GNU Toolchain for embedded ARM development and made =
> myself a build manifest for it.
> My libraries which are defined with the "lib" valueType won't get pass=
ed =
> to the commandline.
> Simon Bitschnau
Previous Topic:Eclipse crashes easily
Next Topic:C++ in Eclipse
Current Time: Fri Nov 07 17:27:46 EST 2025
Powered by FUDForum. Page generated in 0.02605 seconds
