Home » Language IDEs » ServerTools (WTP) » wtp and .properties files, specifically log4j
wtp and .properties files, specifically log4j [message #162963] Mon, 06 March 2006 19:10 Go to next message
Originally posted by: ciaron.dodgeit.com
The documentation I'm am currently reading (the official spring starter
tutorial) mentions putting the log4j.properties config file into
WEB-INF/classes, however when I create that file, WTP does not seem to
deploy the file, or any other i put in that folder. The files do not seem
to get copied across to .deployables. Is there something I need to
configure for this to happen? Or should I be putting the .properties files
elsewhere.
cheers,
Ciaron
Re: wtp and .properties files, specifically log4j [message #163093 is a reply to message #162963] Tue, 07 March 2006 09:39 Go to previous message
Originally posted by: dserodio.gmail.com
Ciaron Nixon wrote:
> seem to get copied across to .deployables. Is there something I need to
> files elsewhere.
You should put any .properties files in a Source Folder, and Eclipse
will copy them to the "target folder". This works for both WTP and
"pure" Java projects. In WTP's case, the "target folder" is WEB-INF/classes/
HTH,
Daniel Serodio
Previous Topic:Validating XML with other file suffixes
Next Topic:Problem building .war from eclipse
Current Time: Sat Nov 08 05:54:14 EST 2025
Powered by FUDForum. Page generated in 0.02606 seconds
