Home » Modeling » GMF (Graphical Modeling Framework) » Figure with two Anchors
Figure with two Anchors [message #161052] Sun, 18 November 2007 09:50 Go to next message
Originally posted by: martin.tauber.t-online.de
Hello Newsgroup,
I am trying to create a Figure with two Anchors (Let's say NORTH and
SOUTH). How do I do this. (Please do not refer me to any of the
examples, because they are just to complex!)
Martin
Re: Figure with two Anchors [message #161076 is a reply to message #161052] Sun, 18 November 2007 11:02 Go to previous messageGo to next message
This is a GEF question, so I suggest you post this question to that
newsgroup (eclipse.tools.gef) after first searching its history. I know
you're not interested in the examples, but the GEF logic diagram example get
you close.
- Rich
On 11/18/07 9:50 AM, in article fhpjgd$t4f$1@build.eclipse.org, "Martin
Tauber" <martin.tauber@t-online.de> wrote:
> Hello Newsgroup,
> Thanks
> Martin
Re: Figure with two Anchors [message #161084 is a reply to message #161076] Sun, 18 November 2007 12:50 Go to previous messageGo to next message
No it's not a gef question. GMF runtime uses methods like
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPa rt#getSourceConnection
and
org.eclipse.gmf.runtime.gef.ui.figures.NodeFigure#getConnect ionAnchors.
Since this is the GMF runtime I guess the invetor of the runtime had an
idea how to integrate anchors into gmf. So still: How do I just simply
add two anchors NORTH and SOUTH to the figure?
I really think this is one of the basic concepts of gmf and I am very
suprised how little knowledge about this concept there is in the field.
Martin
P.S. Are any gmf developers reading this newsgroup?
> you close.
> - Rich
>> Hello Newsgroup,
>> Thanks
>> Martin
Re: Figure with two Anchors [message #161148 is a reply to message #161084] Sun, 18 November 2007 20:20 Go to previous messageGo to next message
Your question was in reference to figures and anchors, both of which are
GEF/draw2d concepts, and made no mention to anything GMF-specific. GMF
builds upon GEF, so there are obviously related classes/methods. I'd start
by looking at the hierarchy for org.eclipse.draw2d.ConnectionAnchor.
You'll find that your questions will get a better response if you include
specific details, as in the question about 2.0.1 installation.
- Rich
On 11/18/07 12:50 PM, in article fhpu3f$jib$1@build.eclipse.org, "Martin
> tion
> and
> Regards
> Martin
>> you close.
>> - Rich
>>> Hello Newsgroup,
>>> Thanks
>>> Martin
Re: Figure with two Anchors [message #161177 is a reply to message #161052] Mon, 19 November 2007 04:38 Go to previous messageGo to next message
Originally posted by: biju_gopinathan.rediffmail.com
--------------090104030506030307010606
Hello Martin,
Are you trying to do something like in the attached image. If yes
then you should set the "Affixed Parent Side" property of your child
node's(node's which should act as anchors for you) should be set to
NORTH and SOUTH respectively in the .gmfgraph file.
Regards, :) Biju
Martin Tauber wrote:
> Hello Newsgroup,
> Thanks
> Martin
Content-Type: image/bmp;
name="anchor.bmp"
Content-Disposition: inline;
filename="anchor.bmp"
Qk3atgIAAAAAADYAAAAoAAAAJAEAAMsAAAABABgAAAAAAKS2AgAAAAAAAAAA AAAAAAAAAAAA
////////tbW1sLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCw sLCwsLCwsLCw
sLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCw sLCwsLCwsLCw
sLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwtbW1 ////////////
////////////////////////sLCw//////////////////////////////// ////////////
sLCw//////////////////////////////////////////////////////// ////////////
////////////////////////////////////////sLCw//////////////// ////////////
////////////////sLCw//////////////////////////////////////// ////////////
////////////////////////////////////////////////////////sLCw ////////////
////////////////////////////////sLCw//////////////////////// ////////////
////////////////////////////////////////////////sLCw//////// ////////////
//////////////////////////////////////////////////////////// ////sLCw////
////////sLCw//////////////////////////////////////////////// ////////////
////////sLCw////////////////////////////////////////////7vXu qseqj66PlKyU
q6+rsLCwsLCwsLCwsLCwlKyUkK6QpcOl4u3i//////////////////////// ////////////
////////////////////////sLCw//////////////////////////////// ////w9nDkK6Q
q6+rdKB0QpFCLIssBoEGAH8AAH8AAH8AAH8ALIssPZA9bp5uoKygmK2YtdC1 ////////////
Re: Figure with two Anchors [message #161405 is a reply to message #161148] Mon, 19 November 2007 10:43 Go to previous messageGo to next message
Hi Rich,
sorry if I may sound rude, but I think it is a very simple and elematary
question and I would have thought that there would be a simple answer to
it. Let me explain more specific:
I am creating a flowchart diagram. The flowchart diagram contains a
diamand figure for a Branch. Now I would be able to start connections
only at the corners of the Diamand. I understand that Connections need a
source and a target anchor and I see that the default anchor created by
GMF for the ShapeNodeEditPart is a ChopboxAnchor.
Looking at the Classes involved I found methods for the <branch>EditPart
which returns the Anchor getSourceConnectionAnchor(...) and
getTargetConnectionAnchor(...). overriding these methods work fine. But
now I want to create an anchor depending on which of the diamonds
corners is the closest.
Looking at the NodeFigure class I saw poorly documented methods that
also deal with anchor like getSourceConnectionAnchorAt(...) These look
like they could be dealing with the situation, but scanning the source
code they don't seam to be doing so.
So I have already invesigated a bit to find a solution for the question
on how to set anchors for my figure. I like the idea of having the
figure telling me what anchors it supports and not the editpart. (Since
the figure knows its shape ...)
Now my ultimate question again: What is the best practice in GMF to set
the anchors according to my requirements.
If you need more information please don't hesitate to contact me!
Martin
start
> - Rich
>> tion and
>> Regards
>> Martin
know
example get
>>> you close.
>>> - Rich
>>>> Hello Newsgroup,
>>>> Thanks
>>>> Martin
Re: Figure with two Anchors [message #161664 is a reply to message #161405] Tue, 20 November 2007 06:45 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Hello!
Interface org.eclipse.gef.NodeEditPart exposes contract of editpart to
support incoming and outgoing connections and it's well documented. GMF
introduces ShapeNodeEditPart and NodeFigure so editpart asks figure for
anchors but the contract of NodeEditPart remains in power. So you should
write your own custom connection anchor and subclass NodeFigure of your
editpart to return your custom anchors.
> Hi Rich,
> Regards
> Martin
> start
> include
> > - Rich
> >> tion and
> >> Regards
> >> Martin
> know
> example get
> >>> you close.
> >>> - Rich
> "Martin
> >>>> Hello Newsgroup,
> >>>> Thanks
> >>>> Martin
Re: Figure with two Anchors [message #161673 is a reply to message #161664] Tue, 20 November 2007 07:57 Go to previous messageGo to next message
Hi Martin,
Sorry, but for some reason your reply below does not appear in my news
client, although Dmitry's reply does (obviously).
I used a variant of FixedConnectionAnchor to accomplish something similar to
what you're looking for, returning it from getTargetConnectionAnchor(), just
as Dmitry suggests. While I agree it should be easier to
define/restrict/select anchor points, I don't know of a way other than to
write this code yourself.
Maybe look at BorderItemConnectionAnchor as well?
- Rich
On 11/20/07 6:45 AM, in article fhuhcd$ovl$1@build.eclipse.org, "Dmitry
Stadnik" <5d5@mail.ru> wrote:
> Hello!
>> Hi Rich,
>> Regards
>> Martin
>> start
>> include
>>> - Rich
>> c
>>>> tion and
>>>> Regards
>>>> Martin
>> know
>> example get
>>>>> you close.
>>>>> - Rich
>> "Martin
>>>>>> Hello Newsgroup,
>>>>>> Thanks
>>>>>> Martin
Re: Figure with two Anchors [message #161882 is a reply to message #161673] Wed, 21 November 2007 11:09 Go to previous message
Originally posted by: malte.koelling.udo.edu
Hello Martin,
I think this might help you. I also use 2 fixed anchor points for my
figure.
http://www.eclipse.org/newsportal/article.php?id=8023&gr oup=eclipse.modeling.gmf#8023
If you would like to have a concret example just ask.
Malte
Previous Topic:GMF Problem -> Once one node added, none other can be
Next Topic:Edit an existing ResourceSet in a GMF editor
Current Time: Mon Nov 17 23:48:10 EST 2025
Powered by FUDForum. Page generated in 0.05671 seconds
