| Where to change attributes from code? [message #161006] |
Fri, 16 November 2007 12:53  |
Originally posted by: malte.koelling.udo.edu
as many people I would like to chance attributes of my model out of my
program. The plan is to set an index number according to the number of
already existing elements of this type. So for example if there already 2
models of type "Task" and I make a new one its index should be "3".
I read the Newsgroup Q&A about this topic and this post.
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03870.html
But I did not get it, where to put this code? Shall I put it in the
"TaskEditHelperClass" in my diagram plugin? But this class seems never to
be called if create a new element. Do I have to register this class
somewhere, so that it is called everytime a new object "Task" was created?
Best Regards and thanks
Malte
| Re: Where to change attributes from code? [message #162576 is a reply to message #161876] |
Sat, 24 November 2007 21:42  |
Originally posted by: Sam.sam.org
private class ChangeAttrCommand extends Command {
public ChangeAttrCommand (Element element, Attribute attr, value) {
setLabel("set attr");
this.element = element;
public boolean canExecute() {
return true;
public boolean canUndo() {
return false;
public void execute() {
IUndoableOperation op = new AbstractEMFOperation(getEditingDomain(), "") {
protected IStatus doExecute(IProgressMonitor monitor, IAdaptable info)
throws ExecutionException {
attr.setValue(value);
return Status.OK_STATUS;
try {
op.execute(new NullProgressMonitor(), null);
} catch (ExecutionException e) {
FUDForum. Page generated in 0.03990 seconds
