Home » Language IDEs » Java Development Tools (JDT) » M9: Compiler Adapter can't be found
M9: Compiler Adapter can't be found [message #160183] Sun, 23 May 2004 16:09 Go to next message
Originally posted by: awmobjects.yahoo.com
I get the subject failure message when I run my build.xml script from
within eclipse (right_clk --> Run --> Ant Build)
My build.xml snippert:
<property name="build.compiler"
value="org.eclipse.jdt.core.JDTCompilerAdapter"/>
Any thoughts would be appreciated.
Anthony
Re: Compiler Adapter can't be found [message #160191 is a reply to message #160183] Sun, 23 May 2004 21:29 Go to previous messageGo to next message
Ensure that you are running you Ant build in the same VM as Eclipse.
See the JRE tab for your Ant launch configuration.
You can use the JDT compiler adapter in a separate VM if you so desire but
then you need to explicitly add the jdtCompilerAdpater.jar and appropriate
JDT core JARs to the Ant runtime classpath.
HTH
Darins
"Anthony W. Marino" <awmobjects@yahoo.com> wrote in message
news:c8qvvf$o1b$1@eclipse.org...
> Anthony
Re: Compiler Adapter can't be found [message #160461 is a reply to message #160191] Mon, 24 May 2004 19:34 Go to previous messageGo to next message
Is there somewhere to set this globally? The only place I was able to
find this setting was in the process of running the ant file.
Anthony
> HTH
> Darins
>>Thanks,
>>Anthony
Re: Compiler Adapter can't be found [message #160487 is a reply to message #160461] Mon, 24 May 2004 19:46 Go to previous messageGo to next message
No you cannot set this globally.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38263
Darins
news:c8u0c1$38e$1@eclipse.org...
> Anthony
but
appropriate
> > HTH
> > Darins
> >>Thanks,
> >>Anthony
Re: Compiler Adapter can't be found [message #160502 is a reply to message #160487] Mon, 24 May 2004 20:29 Go to previous messageGo to next message
Wow, over a year old.
Anthony
> Darins
>>Anthony
> but
> appropriate
>>>HTH
>>>Darins
>>>>Thanks,
>>>>Anthony
Re: Compiler Adapter can't be found [message #160509 is a reply to message #160502] Mon, 24 May 2004 20:45 Go to previous message
Yep... I have had to fix a few other bugs in that time frame :-)
Darins
news:c8u3ir$6l8$1@eclipse.org...
> Anthony
> > Darins
> >>Anthony
> > but
> > appropriate
> >>>HTH
> >>>Darins
> >>>>Thanks,
> >>>>Anthony
Previous Topic:Getting notifications for Job.cancel()
Next Topic:questions on parser, symbol table and indexer
Current Time: Fri Oct 10 06:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.04161 seconds
