Home » Eclipse Projects » GEF » Group or dock Figure/Editparts
Group or dock Figure/Editparts [message #159665] Tue, 30 November 2004 03:46 Go to next message
Originally posted by: carroe.gmx.net
i want to dock (group) two Figures/Editparts, so that:
* their models get connected somehow
* their contraints (size/position) are changend synchronous
(proportional/by difference)
There is no such parent<>child relationship between the model elements
as with 'AbstractEditPart.getModelChildren()'. They are more or less
considered to be on a equal level, so it would be more like
<EditPart>.getDockedElements().
Where would be the best starting point for the dockable/docking part?
Specialize AbstractGraphicalEditPart? Or even deeper?
Any suggestions?
Tnx.
Carsten
Re: Group or dock Figure/Editparts [message #159683 is a reply to message #159665] Tue, 30 November 2004 07:55 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
The rule of thumb is to think from the model point of view, not from the
editor UI POV.
I.e. in case you have docking you should reflect this in your model (i.e.
when one model position changes, change the position of the second model)
and then propagate it to the editor.
From the GEF point of view, if you want to implement docking it seems like
you can toggle dock state in response to Add/Orphan requests (i.e. when you
drag objectA on top of objectB, objetB editpart will receive the add request
so you can change the feedback painting and update the docked state of the
model)
Eugene
"Carsten" <carroe@gmx.net> wrote in message
news:cohc0g$6b1$1@www.eclipse.org...
> Any suggestions?
> Tnx.
> Carsten
Re: Group or dock Figure/Editparts [message #159800 is a reply to message #159683] Tue, 30 November 2004 11:36 Go to previous message
> editor UI POV.
Definitely the docked state has to be persisted, so that's the starting
point.
you
request
> model)
Are you talking about toggling dock, or respecting it? To drag 2 items as
if they were docked, you might want to:
1) Link selection, such that if one item is selected all docked items are
too
2) Link the model. Reparent the children into a new composite object, which
has just one selectable editpart (although you can still use children to
build the figures)
3) Forward requests. If an object is being dragged, forward requests to
other editparts which are linked but not selected.
2 is probably what I would expect as a user.
> Eugene
> > Hi,
> > Any suggestions?
> > Tnx.
> > Carsten
Previous Topic:How to remove the history- and team related menuitems in the context menu?
Next Topic:Figure export OutOfMemory
Current Time: Thu Nov 20 07:01:39 EST 2025
Powered by FUDForum. Page generated in 0.07213 seconds
