Home » Eclipse Projects » GEF » how to fillGradient in shapes other than rectangle
how to fillGradient in shapes other than rectangle [message #157204] Mon, 08 November 2004 05:59 Go to next message
How can I fillGradient in shapes, such as Ellipse?
I've tried
Ellipse circle = new Ellipse(){
public void paintFigure(Graphics g){
Re: how to fillGradient in shapes other than rectangle [message #157213 is a reply to message #157204] Mon, 08 November 2004 06:05 Go to previous messageGo to next message
How can I fillGradient in shapes, such as Ellipse, Polygon?
I've tried
g.fillGradient(0,0,100,100, true);
but it turns out a rectangle figure filled gradient and the ellipse is
gone.
Is there any way I can fill a shape other than rectangle with gradient
color?
thanks in advance
Kate
Re: how to fillGradient in shapes other than rectangle [message #157230 is a reply to message #157204] Mon, 08 November 2004 07:50 Go to previous messageGo to next message
AFAIK only GC#fillGradientRectangle supported by SWT. Seems that if you want
advanced features then you need to implement more advanced GC first. You may
also look at http://www.holongate.org/ - seems that such pulg-in may help.
as
"Kate" <katelin@tw.ibm.com> ???????/???????? ? ???????? ?????????:
news:cmnji2$f3h$1@eclipse.org...
> I've tried
Re: how to fillGradient in shapes other than rectangle [message #157353 is a reply to message #157213] Tue, 09 November 2004 00:28 Go to previous messageGo to next message
Hmm, that's a good question. You might want to try the platform newsgroup
and find out if there's a way to do that with GC. Our Graphics object
delegates to GC, so if you can do it with GC's public methods, you should be
able to do the same with Graphics. However, it doesn't seem like you can do
that.
BTW, with a Shape (such as Ellipse), you shouldn't override paintFigure().
Instead override fillShape() and outlineShape() as needed.
"Kate" <katelin@tw.ibm.com> wrote in message
news:cmnjtf$ihm$1@eclipse.org...
> I've tried
> gone.
> color?
> thanks in advance
> Kate
Re: how to fillGradient in shapes other than rectangle [message #157375 is a reply to message #157353] Tue, 09 November 2004 02:30 Go to previous message
Perhaps, you could use clipping before painting the bounding rectangle...
David
> that.
>>I've tried
>>gone.
>>color?
>>thanks in advance
>>Kate
Previous Topic:Rounding errors in figure drawing
Next Topic:Creating connections - help
Current Time: Mon Nov 17 02:19:18 EST 2025
Powered by FUDForum. Page generated in 0.03699 seconds
