| New user - Please help [message #157020] |
Fri, 14 November 2003 13:29  |
I just started using eclipse. I am having some difficulties in creating
a java project. Please help.
Here is my problem. I am using eclipse 3.0. I want to create a java
project, but the source files and the output files should be in a file
system outside the project's resource hierarchy. I thought I should
create the source folder as a "Linked resource". I did that by creating
a new folder under the root resource. I did that from the projects
properties dialog, "Java Build Path", "Source" tab, I clicked on "Add
Folder" -> "Create New Folder". I specified the folder name and in the
advanced tab, I checked "Link to folder in file system" and specified
the actual path to where the source reside. Now in the "Package
Explorere" view, I see the various java packages. If I double click on
any of the java sources in the package, I get an error
"Cannot open default editor on <filename>. Editor could not be initialized.
But if I open the file using "open with" -> "text editor", I am able to
open the file. But I don't see any syntax highlighting etc. So my
questions are:
1. How can I create a java project where the source files and the class
files reside in a file system outside the project's resource hierarchy.
2. If "Linked resources" are the way the to do this, why am I not able
to open any files using Java editor.
Anand
| Re: New user - Please help [message #157318 is a reply to message #157020] |
Sat, 15 November 2003 12:01   |
Originally posted by: daniel.megert.gmx.net
Anand Narasimhan wrote:
> creating a java project. Please help.
> creating a new folder under the root resource. I did that from the
> projects properties dialog, "Java Build Path", "Source" tab, I clicked
> on "Add Folder" -> "Create New Folder". I specified the folder name
> and in the advanced tab, I checked "Link to folder in file system" and
> specified the actual path to where the source reside. Now in the
> "Package Explorere" view, I see the various java packages. If I double
> click on any of the java sources in the package, I get an error
> initialized.
> to open the file. But I don't see any syntax highlighting etc. So my
> questions are:
> class files reside in a file system outside the project's resource
> hierarchy.
Everything you did is correct. I assume you are using 3.0 M4. This is a
known problem which has been fixed in the current stream.
Dani
> Thanks
> Anand
| Re: New user - Please help [message #157511 is a reply to message #157318] |
Sun, 16 November 2003 16:04   |
Hi Dani,
Thanks for the reply. yes, I am using 3.0M4. What is the current stream?
Anand
>> initialized.
>> questions are:
>> hierarchy.
> Dani
>> Thanks
>> Anand
FUDForum. Page generated in 0.03651 seconds
