Home » Language IDEs » Java Development Tools (JDT) » JUnit not working in 3M7
JUnit not working in 3M7 [message #156950] Sat, 01 May 2004 17:15 Go to next message
Originally posted by: ccullum.yemtech.com
I will still have a problem with running JUnit in eclipse. If someone
would help me out, I would not have to keep posting. Here is what I do:
1. Create a test folder under my project
2. While the test folder is highlighted, I click on File->New->Other
3. I select Java->JUnit->TestCase
4. I set my source folder to be my project/test folder
5. I set the package to com.Users
6. I set the name to UserTest
7. I keep the superClass the same.
8. I change the Class to test to com.Users.User
9. I click Next
10. I choose my methods I want to create tests for.
11. I click on the Finish
12. I change the UserTest.suite() call to UserTest.class
13. I make sure that the UsertTest.java is highlighted and I click on
Run->RunAs->Junit Test
14. The Console comes up and says "Class not found com.Users.UserTest"
Why is this?
Christopher Cullum
Re: JUnit not working in 3M7 [message #157261 is a reply to message #156950] Tue, 04 May 2004 20:02 Go to previous message
Originally posted by: rtayek.no.spam.freightgate.com
"Christopher Cullum" <ccullum@yemtech.com> wrote in message
news:pan.2004.05.01.21.15.48.720281@yemtech.com...
> I will still have a problem with running JUnit in eclipse....
try making the packagename lower case: i.e. com.users.
maybe it thinks it's an inner class? in any case try to find the
com.Users.UserTest.class file.
hth
Previous Topic:No local variables when debugging java.lang.Integer
Next Topic:loading a plugin dynamically
Current Time: Tue Jul 15 19:38:25 EDT 2025
Powered by FUDForum. Page generated in 0.03740 seconds
