Home » Eclipse Projects » SWTBot » Library.xml not exist in swtbot 2.1(Library.xml not exist in swtbot 2.1)
Library.xml not exist in swtbot 2.1 [message #1058212] Mon, 13 May 2013 04:56 Go to next message
Library.xml not exist in swtbot 2.1.
I installed swtbot 2.1 from latest update site in Juno 4.2 but there is no extracted folder of "org.eclipse.swtbot.eclipse.junit.headless_2.1.0.201302221524" to read library.xml for running headless. Do anyone has any idea how to run test cases headless in juno with latest version of swtbot.
Re: Library.xml not exist in swtbot 2.1 [message #1058229 is a reply to message #1058212] Mon, 13 May 2013 05:32 Go to previous messageGo to next message
Library.xml is not necessary to use SWTBot headless with Ant.
You can get more details here:
http://wiki.eclipse.org/SWTBot/Automate_test_execution#Installing_headless_Testing_Framework
The library.xml is still in org.eclipse.swtbot.eclipse.junit.headless ,
but you'll need to unjar the bundles if you want to use it.
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Library.xml not exist in swtbot 2.1 [message #1058234 is a reply to message #1058212] Mon, 13 May 2013 05:57 Go to previous messageGo to next message
Thanks Mickael for your prompt reply. I extracted the bundle and run the test cases through ant script but i am getting below error
java.lang.RuntimeException: Application "org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFileEditor, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer, org.eclipse.pde.build.Build, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.legacytestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication, org.eclipse.ui.ide.workbench, org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.wst.server.preview.preview, org.eclipse.swtbot.eclipse.core.swtbottestapplication, org.eclipse.swtbot.eclipse.junit.headless.swtbottestapplication.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
at org.eclipse.core.launcher.Main.main(Main.java:34)
Re: Library.xml not exist in swtbot 2.1 [message #1058245 is a reply to message #1058212] Mon, 13 May 2013 06:38 Go to previous messageGo to next message
I have changed in library.xml file from
to
Now i m getting some other message in logs:
Caused an ERROR
java.lang.Exception: Could not find plugin "com.testing.test"
org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner$TestFailedException: java.lang.Exception: Could not find plugin "com.testing.test"
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.runFailed(EclipseTestRunner.java:289)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:242)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.<init>(EclipseTestRunner.java:222)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.run(EclipseTestRunner.java:206)
at org.eclipse.swtbot.eclipse.junit.headless.UITestApplication.runTests(UITestApplication.java:116)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.Exception: Could not find plugin "com.testing.test"
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.loadSuiteClass(EclipseTestRunner.java:303)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:239)
But com.testing.test.jar is already in plugins folder.
Any clue ?
[Updated on: Mon, 13 May 2013 06:39] by Moderator
Re: Library.xml not exist in swtbot 2.1 [message #1058395 is a reply to message #1058245] Mon, 13 May 2013 17:39 Go to previous messageGo to next message
> to org.eclipse.swtbot.eclipse.junit.headless.swtbottestapplication
That was the right move. You should consider contributing that change to
SWTBot: http://wiki.eclipse.org/SWTBot/Contributing
> Caused an ERROR
Is com.testing.test your test bundle? If yes, did you make sure it's
available in the instance of Eclipse you're using to test? Ideally, you
should have it installed in your test app using p2 director so you get
sure it's installed with all its dependencies.
Mickael Istria
JBoss, by Red Hat
Re: Library.xml not exist in swtbot 2.1 [message #1058430 is a reply to message #1058395] Tue, 14 May 2013 01:34 Go to previous messageGo to next message
yes "com.testing.test" is my swtbot test plugin. I exported the same and copy "com.testing.test_1.0.jar" to eclipse/plugins folder but no luck. Still getting the same exception:
Re: Library.xml not exist in swtbot 2.1 [message #1059265 is a reply to message #1058430] Wed, 15 May 2013 11:06 Go to previous message
Copying is not the right way to install stuff in an Eclipse. You should
either use p2 director to install, or try to put it in the dropins folder.
Mickael Istria
JBoss, by Red Hat
Previous Topic:SWTBot headless testing
Next Topic:SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2
Current Time: Fri Oct 31 13:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.04338 seconds
