Classpath problems when building plugins in M8 [message #156329] |
Wed, 28 April 2004 10:41  |
After switching to version M8, I can't build my plugins anymore, because
of problems relating to the build-path.
Initially, (i.e. the 1st time I tried M8) they built & ran fine.
Now, the dynamic plug-in dependencies calculation seems to be failing
(it returns no dependencies).
Setting the build-path to include the Eclipse plugins I reference,
produces the build-error:
"The type org.osgi.framework.BundleActivator cannot be resolved. It is
indirectly referenced from required .class files."
As far as I'm aware, I haven't changed anything that should cause problems.
Any help/insight would really be appreciated.
- Dan
Re: Classpath problems when building plugins in M8 [message #156657 is a reply to message #156564] |
Thu, 29 April 2004 12:38  |
The best bet is to move to a later integation build.
I20040427 or I20040428.
I have not found a consistent workaround for cleaning up a workspace once it
has gone "bad".
I have had some success with closing projects, re-opening and then getting a
build to occur.
Darins
"Daniel Winterstein" <danielw@dai.ed.ac.uk> wrote in message
news:c6qhtf$foq$1@eclipse.org...
> Thanks - I think you're right. I couldn't quite follow the comments on
> Bugzilla. Is there a work-around for this bug?
> - Dan
> Darin Swanson wrote:
> > I believe you may be seeing
> > https://bugs.eclipse.org/bugs/show_bug.cgi?id=57181
> > HTH
> > Darins
> > news:c6off9$a4t$3@eclipse.org...
> > problems.
> >>Thanks,
> >> - Dan
FUDForum. Page generated in 0.07995 seconds
