Home » Language IDEs » Java Development Tools (JDT) » How to create a WAR file. I failed to do so even after using the Sysdeo Plug-in
How to create a WAR file. I failed to do so even after using the Sysdeo Plug-in [message #155108] Tue, 20 April 2004 07:37
Originally posted by: daspranabesh.lycos.com
I am working with Eclipse IDE for the last 7-8 months. I am facing a
particular problem and did not find any reason behind this.
I am basically working with Web Applications and already installed the
Sysdeo Tomcat Plugin to work with Eclipse. But while trying to set the
name of a file in Project>Properties>Tomcat>Export to WAR settings>WAR
file to export input box, this value is not persisitng. E.g. I set this
parameter to be C:\Temp\Work.war and press Apply>OK. Then when I try to
export my project to the mentioned WAR file with Project>Tomcat
Project>Export to the WAR file sets in project properties, I get an error
which states that "Operation failed. Destination WAR file should be set in
project properties". When I go to cross check the value set in the said
property, I find that there is no value (which is this should have been
C:\Temp\Work.war).
Anyone with a suitable solution / answer?
Previous Topic:Exception in org.eclipse.core.internal.compatibility.PluginActivator.stop() - unable to start Eclips
Next Topic:Java source code formatting
Current Time: Sat Sep 13 02:01:35 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
