Home » Archived » BIRT » BIRT in a Standalone App - The extension with ID 'org.eclipse.birt.report.data.oda.xml' is not found
BIRT in a Standalone App - The extension with ID 'org.eclipse.birt.report.data.oda.xml' is not found [message #152285] Mon, 10 April 2006 11:44 Go to next message
Originally posted by: calmacroi.myrddin.ch
hi
i want to use birt in a standalone client. in eclipse everything works
fine but when i use the packed software (made with install4j) i get a
message:
how must the classpath look like? do i have to define the plugins xml
files as well in the classpaht?
thanks for any help.
cheers
patrick
URGENT: BIRT in a Standalone App - The extension with ID 'org.eclipse.birt.report.data.oda.xml' is n [message #152482 is a reply to message #152285] Tue, 11 April 2006 07:47 Go to previous messageGo to next message
thanks for any help - its urgent, would be very grateful if someone
could answer me - thanks
Patrick schrieb:
> hi
> message:
> cheers
> patrick
Re: URGENT: BIRT in a Standalone App - The extension with ID 'org.eclipse.birt.report.data.oda.xml' [message #152623 is a reply to message #152482] Tue, 11 April 2006 14:04 Go to previous messageGo to next message
When you say standalone client what do you mean?
Are you using the API or the RCP application?
Jason
"Patrick" <calmacroi@myrddin.ch> wrote in message
news:e1g50l$269$1@utils.eclipse.org...
> thanks for any help - its urgent, would be very grateful if someone could
> answer me - thanks
> Patrick schrieb:
>> hi
>> message:
>> cheers
>> patrick
Re: URGENT: BIRT in a Standalone App - The extension with ID 'org.eclipse.birt.report.data.oda.xml' [message #152694 is a reply to message #152623] Tue, 11 April 2006 17:41 Go to previous messageGo to next message
i'm using the api, i just want to include birt as a set of jar's into my
swing application.
thanks for help
patrick
> Jason
>>answer me - thanks
>>Patrick schrieb:
>>>hi
>>>message:
>>>cheers
>>>patrick
Re: URGENT: BIRT in a Standalone App - The extension with ID 'org.eclipse.birt.report.data.oda.xml' [message #152784 is a reply to message #152694] Tue, 11 April 2006 18:54 Go to previous message
If you look at the report engine api directory in the
report engine download, there is a plugins directory.
Make sure that you set engine home
config.setEngineHome("reportenginedirectory");
When used in a standard Java application the engine will load the plugins in
the plugins directory. Also make sure before packaging that you add iText
to the pdf plugin.
Jason
news:e1h7qk$da9$1@utils.eclipse.org...
> swing application.
> thanks for help
> patrick
>> Jason
>>>answer me - thanks
>>>Patrick schrieb:
>>>>hi
>>>>message:
>>>>found
>>>>cheers
>>>>patrick
Previous Topic:oda and report viewer
Next Topic:XLS Emitter error
Current Time: Wed Nov 05 06:16:46 EST 2025
Powered by FUDForum. Page generated in 0.05077 seconds
