Home » Eclipse Projects » GEF » Does GEF support a hierarchical layout of nested subgraphs?
Does GEF support a hierarchical layout of nested subgraphs? [message #152243] Tue, 28 September 2004 10:08 Go to next message
I am evaluating GEF as a possible candidate to allow me to visualise code
dependencies.
Please answer the following questions if you have experience in this area:
1.) Is it possible to create large, connected, nested subgraphs with
using GEF? An example would be two projects, each containing a number of
packages. I must depict dependencies between the packages both inside a
project and between projects.
2.) Does a good hierarchical layout exist for handling such nested
subgraphs?
Many thanks,
Michael Marconi
Re: Does GEF support a hierarchical layout of nested subgraphs? [message #152255 is a reply to message #152243] Tue, 28 September 2004 11:14 Go to previous message
> subgraphs?
A hierarchical layout exists. CompoundDirectedGraphLayout. It is a
stand-alone algorithm which can be bridged into draw2d/gef.
> Many thanks,
> Michael Marconi
Previous Topic:collapse/expand nested container problem
Next Topic:How to change the backround color of a label
Current Time: Sat Nov 08 02:15:30 EST 2025
Powered by FUDForum. Page generated in 8.83980 seconds
