Home » Eclipse Projects » Mylyn » Zest
Zest [message #14242] Tue, 17 July 2007 18:12 Go to next message
Originally posted by: richard.richardmiskin.plus.com
Can built zest plugins be downloaded from anywhere? Or do I need to check out the code from CVS?
I can't see them in the Mylyn update sites for Europa.
Richard
Re: Zest [message #16079 is a reply to message #14242] Thu, 19 July 2007 15:10 Go to previous messageGo to next message
If needed Ian Bull (owner of the Zest component) can comment further
once he returns from, but as as far as I know you still need to check
out Zest from CVS by following the instructions at the bottom of:
http://www.eclipse.org/mylyn/zest.php
Mik
Re: Zest [message #17445 is a reply to message #16079] Fri, 20 July 2007 10:17 Go to previous message
Thanks for getting back to me. I've just worked out why I didn't see that page, I'd used an old link to http://www.eclipse.org/mylar/zest, which takes you to http://www.eclipse.org/mylyn/moved.php which then takes you to http://www.eclipse.org/mylyn/ which doesn't seem to reference Zest.
But I know where to look now, so thank you.
Richard
Re: Zest [message #573604 is a reply to message #14242] Thu, 19 July 2007 15:10 Go to previous message
Mik
Re: Zest [message #574132 is a reply to message #16079] Fri, 20 July 2007 10:17 Go to previous message
Richard
Previous Topic:Question regarding saved context
Next Topic:Is there any way to get a list of modified resources?
Current Time: Sun Nov 09 18:03:38 EST 2025
Powered by FUDForum. Page generated in 0.03891 seconds
