| Dangling Connection [message #151836] |
Thu, 20 September 2007 07:04 |
I would like to be able to create a dangling connection, that is, a
connection that is only connected at one end. Eventually it would be
connected at both ends. I understand from the documentation that a
connection requires both a source and target so I cannot use a connection.
I wanted to try to create a simple polyline node figure that is not
mapped to anything but I can't generate when I attempt this. So I guess I
have two questions:
1) Has anyone created a dangling connection before? Is it even possible?
2) Can you generate when you have a figure that does not have a domain
element?
FUDForum. Page generated in 0.04000 seconds
