| Urgent:Passing Design Object to Run/Render task & cacheing ??? [message #151748] |
Fri, 07 April 2006 02:53 |
Originally posted by: akash.patil.yaanesites.com
Hi ,
Its an Urgent need
I am Integrating BIRT with our web application which runs on tomcat server.
In many cases we need the report to be generated dynamically ,so I am
using Design Engine API to generate report .
I have an another class which is used for running & rendering the report
I am streaming the generated HTML report to an OutputStream.
How can i directly pass the design object generated using Design Engine
API to run/render task for execution instead of saving it to disk in
rptdoc & rptdesign files.
Another problem is , I need the same report to cached for export to CSV ?
how can i do that?
Thanking you
Akash
FUDForum. Page generated in 0.02896 seconds
