Home » Eclipse Projects » Eclipse Platform » Do I need 2 java docs?
Do I need 2 java docs? [message #151510] Thu, 30 October 2003 10:19 Go to next message
Originally posted by: a.abc.com
Just downloaded & installed j2sdk1.4.2_02
(j2sdk-1_4_2_02-windows-i586-p.exe) & accompying API documentation
j2sdk-1_4_2-doc.zip & set java doc location to this in Eclipse which works
fine!
I say fine, but these doc's do not include httpsession etc... stuff, so I
found another api doc j2eesdk-1_4-beta2-doc-apidocs.zip which does have the
enterprise doc's in.
Now how can I setup eclipse to open up either depending on the object I'm
pressing shift+f2 on? - do I have to expand them both into the same
directory & some how merge the package-list files? or what?
There must be a simple way but then again this is Java!
I'm running Eclipse 2.1.1 & myeclipse & deploying to a Weblogic 6.1 server.
thanks
harry
Re: Do I need 2 java docs? [message #151516 is a reply to message #151510] Thu, 30 October 2003 10:51 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
I think there must be a j2ee.jar or something which contains the below
mentioned stuff. If this is the case you can attach javadoc to that jar as
well (see project properties-->java build path-->libraries).
HTH,
Csaba
"Harry" <a@abc.com> wrote in message news:bnra41$edu$1@eclipse.org...
> fine!
the
server.
> thanks
> harry
Previous Topic:Using multiple workspaces ...
Next Topic:Where is Update Manager/External Preview in Eclipse R3 M4?
Current Time: Tue Sep 16 18:11:21 EDT 2025
Powered by FUDForum. Page generated in 0.02427 seconds
