Home » Archived » BIRT » Highlights in PDF report
Highlights in PDF report [message #148986] Tue, 28 March 2006 09:37 Go to next message
Originally posted by: daniele.stroppa.atkinsglobal.com
Hi everybody,
I've made a report with a table in it and the content of each cell is
highlighted in a different way depending on the value of a field. The
report is showed properly in the preview and run method, but when I select
the pdf format it doesn’t show any highlights: the table is there, all the
headings are there too, but all the cells are empty, just white!
I'm using BIRT engine 2.0.1 on a RHE server with Apache Tomcat 5.0.28
Any idea?
Dan
Re: Highlights in PDF report [message #149077 is a reply to message #148986] Tue, 28 March 2006 12:13 Go to previous messageGo to next message
It works for me on the latest build.
Re: Highlights in PDF report [message #150205 is a reply to message #149077] Mon, 03 April 2006 09:04 Go to previous message
I've tried with BIRT 2.1M5, but still same result. HTML preview is showing
colors, while pdf is not.
any other ideas?
thanks
Previous Topic:Export - Urgent HELP required.
Next Topic:Generating chart in HTML
Current Time: Thu Oct 23 04:38:06 EDT 2025
Powered by FUDForum. Page generated in 0.06585 seconds
