| How to set boolean attribute value [message #148472] |
Thu, 30 August 2007 04:44  |
Originally posted by: elena.renzi.gmail.com
I should set a boolean attribute to true, its default value is false. I
tried to use "Feature Seq Initializer" under "Node Mapping" for node
representing the object with his attribut set to true, then I add "Feature
Value Spec" but I don't know how to specify this property in the body...I
thought I should use java as language, but which expression should I use?
Thanks in advance!
Elena
| Re: How to set boolean attribute value [message #148495 is a reply to message #148487] |
Thu, 30 August 2007 05:33  |
No, I don't want to set true as his initial value. I have an Eclass in my
Ecore model with an EAttribute, which initial value is false. Now I want
to map this EClass in two different Node, the first one, with the
attribute set to its default value(false), the second with the attribute
set to true...
Thanks for your help!
FUDForum. Page generated in 0.06089 seconds
