How to make a connector touch the shape [message #147857] |
Tue, 17 August 2004 09:24  |
Originally posted by: none.bphnx.com
It should be possible to make a connector touch the shape instead of the
rectangle that surrounds the shape when it is selected, but I cannot
figure out how to do this. For example, when you connect a connector to a
Triangle, the connector does not make contact with the Triangle itself.
Any hints on this?
many thanks,
B
Re: How to make a connector touch the shape [message #148012 is a reply to message #147872] |
Wed, 18 August 2004 15:11   |
Hi Randy,
I created my own class that extends AbstractConnectionAnchor. I
overrode the getLocation() method, but no matter what my implementation
is, the connector always attaches to the rectangle that surrounds the
shape ( in this case the shape is a diamond ). It seems to have no effect.
I even tried hardcoding a return new Point(100,100);, but it still
attaches to the rectangle around the diamond. I know I am missing
something else. Any help is greatly appreciated.
thanks,
B
Randy Hudson wrote:
> Use a different ConnectionAnchor for that shape.
> "bandrews" <none@bphnx.com> wrote in message
> news:cft0uc$nus$1@eclipse.org...
> > Any hints on this?
> > many thanks,
> > B
Re: How to make a connector touch the shape [message #148016 is a reply to message #148012] |
Wed, 18 August 2004 17:23   |
Are you sure you didn't override getReferencePoint instead?
Are you setting the anchor on the connection? Is anyone else overwriting
your anchor after you set it?
Put a breakpoint in PolylineConnection.route(), and see what your anchors
are at the time of routing.
news:cg09lv$21p$1@eclipse.org...
> Hi Randy,
> thanks,
> B
the
to a
itself.
> > > Any hints on this?
> > > many thanks,
> > > B
Re: How to make a connector touch the shape [message #148225 is a reply to message #148016] |
Thu, 19 August 2004 17:05  |
Ahhh! The problem was I was overwriting the anchors on the connection
myself. Silly me. Thanks for the hints!
> > Hi Randy,
> > thanks,
> > B
> the
> to a
> itself.
> > > > Any hints on this?
> > > > many thanks,
> > > > B
FUDForum. Page generated in 0.04537 seconds
