Inner class of TheNameEditPart is not TheNameFigure [message #147483] |
Wed, 22 August 2007 14:18 |
Originally posted by: marsha.rohrer.swisscom.com
I have quite a strange problem.
In my ecore model I have defined something like this:
A Class SuperClass then two other classes ClassA and ClassB which both
have the ESuper Type SuperClass.
In the code of the ClassAEditPart I have the inner class named
ClassBFigure. My problem is that I do not see where this error comes from.
It seems that in the ecore model, the gmfgraph and the gmfmap model
everithing is correct. Only in the gmfgen model I can see that the
Metamodel Type of the Gen Top Level Node of the ClassAEditPart is ClassB
instead of ClassA.
I don't want to modify the gmfgen, since I'll have this problem any time I
change something.
Does someone see where the problem could come from? Or should I just
redefine my ecore model from scratch?
Thanks.
Marsha
FUDForum. Page generated in 0.03392 seconds
