| How do you create a JSP file in eclipse 3.1 [message #147265] |
Fri, 07 April 2006 11:08  |
Originally posted by: tgalati.naic.org
I am learning eclipse 3.1 and refreshing myself on Java. I have recently
been put in charge of JSP apps and was hoping someone could tell me how to
create a JSP app within eclipse. When I open a previous .jsp file, it
seems to treat it as a text file and when I go to FILE -> NEW, I don't get
a JSP option.
Is there some plugin or setting I need to turn on?
Any and all help will be greatly appreciated
| Re: How do you create a JSP file in eclipse 3.1 [message #149422 is a reply to message #147288] |
Fri, 21 April 2006 13:32  |
Originally posted by: eclipse3.rizzoweb.com
Tony wrote:
> I downloaded the WTP all in one 1.0 and all required drivers. extracted
> them all to the same directory. Went into eclipse and select WINDOWS ->
> PREFERENCES -> PLUG_IN_DEVELOPMENT -> TARGET PLATFORM and selected the
> eclipse directory that I just extracted too. Is that correct? If so,
> when I click on new, I still don't get the option for .jsp files.
> What am I doing wrong?
Everything, except for downloading WTP.
Seriously, when you installed WTP "all in one" you don't need to link
that with your other Eclipse installation at all. Just run the WTP
all-in-one by itself. I don't know where you got the idea to go into
plug-in development, but that is not relevant in your case (unless I'm
missing something and you are wanting to develop your own plugins for
Eclipse).
Just run the WTP installation and you should be good to go.
Hope this helps,
Eric
FUDForum. Page generated in 0.09128 seconds
