Home » Language IDEs » C / C++ IDE (CDT) » make error "Expecting macro or rule defn, found neither"
make error "Expecting macro or rule defn, found neither" [message #146002] Wed, 25 May 2005 14:02 Go to next message
Originally posted by: swelmer.sbcglobal.net
I searched the newsgroup for this error but couldn't find anything
appropriate. Sorry if it's a duplicate...
I have the PalmSource version of Eclipse and it has been working fine
for quite a while. Suddenly, I get this error *every* time I build a
managed project - even a simple C project with only one source file:
**** Incremental build of configuration Debug for project Test ****
make -k all
make: makefile: line 7: Error -- Expecting macro or rule defn,
found neither
Build complete for project Test
Since this is a managed make project, I don't understand how this could
happen at all and I need a clue about how to fix it. Why would it work
for a long time and then suddenly start happening for all projects??
Anyone have a clue? :-)
Thanks!
Steve
Re: make error "Expecting macro or rule defn, found neither" [message #146023 is a reply to message #146002] Wed, 25 May 2005 14:49 Go to previous messageGo to next message
I should have noted:
I'm working on WinXP SP1, Palm's version is
Version: 1.1.0
Build ID: 15E_110GMC
containing
Eclipse 3.0.1
cdt 2.0.2ps001
> make -k all
> found neither
> Thanks!
> Steve
Re: make error "Expecting macro or rule defn, found neither" [message #146032 is a reply to message #146002] Wed, 25 May 2005 15:03 Go to previous message
Found the problem...
The "Problems" tab in Eclipse didn't bold itself, so I didn't look there
initially. When I *did*, I found a message complaining that make wasn't
GNU make. That sent me to the system variables where I found the PATH
had the cygwin utilities at the very end. Moving it to the front solved
this problem!
Maybe this will at least help someone else :-/
Steve
> make -k all
> found neither
> Thanks!
> Steve
Previous Topic:Problems shown under problems
Next Topic:Importing C++ project into Eclipse on Linux
Current Time: Sun Nov 09 16:37:47 EST 2025
Powered by FUDForum. Page generated in 0.03460 seconds
