Home » Archived » Visual Editor (VE) » [Minor Patch] FormAttachmentBeanInfo
| [Minor Patch] FormAttachmentBeanInfo [message #145911] |
Thu, 16 April 2009 13:43  |
Patch to allow for adding Formattachment to Widgets. This isn't possible
without my patch, but...
Some problems still exists:
1) When setting the offset the source is wrong, instead of
"formData.left = formAttachment2;" it writes
"formData.left(formAttachment);". I've tried to debug this behaviour
with no success, yet!
2)There seems to be some problem when adding two attachments e.g. Top
and Left attachment on a Button in a Shell where the source gets
garbled. (Insertion point seems to be wrong).
Regards.
### Eclipse Workspace Patch 1.0
#P org.eclipse.ve.swt
Index:
vm_swtbeaninfo/org/eclipse/swt/widgets/beaninfo/FormAttachme ntBeanInfo.java
RCS file:
/cvsroot/tools/org.eclipse.ve/plugins/org.eclipse.ve.swt/vm_ swtbeaninfo/org/eclipse/swt/widgets/beaninfo/FormAttachmentB eanInfo.java,v
retrieving revision 1.3
diff -u -r1.3 FormAttachmentBeanInfo.java
24 Aug 2005 23:52:53 -0000 1.3
16 Apr 2009 17:30:42 -0000
@@ -46,8 +46,12 @@
SHORTDESCRIPTION,
resbundle.getString("formattachment.numerator.Desc"), //$NON-NLS-1$
createFieldPropertyDescriptor("offset",
FormAttachment.class.getField("offset"), new Object[]{ //$NON-NLS-1$
//$NON-NLS-2$
- DISPLAYNAME, resbundle.getString("formattachment.offset"),
//$NON-NLS-1$
- SHORTDESCRIPTION,
resbundle.getString("formattachment.offset.Desc"), //$NON-NLS-1$
+ DISPLAYNAME, resbundle.getString("formattachment.offset"),
//$NON-NLS-1$
+ SHORTDESCRIPTION,
+ createFieldPropertyDescriptor("control",
FormAttachment.class.getField("control"), new Object[]{ //$NON-NLS-1$
//$NON-NLS-2$
+ DISPLAYNAME, resbundle.getString("formattachment.control"),
//$NON-NLS-1$
+ SHORTDESCRIPTION,
resbundle.getString("formattachment.control.Desc"), //$NON-NLS-1$
} catch (SecurityException e) {
| Re: [Minor Patch] FormAttachmentBeanInfo [message #145921 is a reply to message #145911] |
Thu, 16 April 2009 17:49  |
In addition I also updated my source to use AST.JLS3, but no changes could be seen in code generation.
Can someone point me in some direction where I should start investigate?
Right now as I'm totally new into EMF, GEF and VE I still havn't grasped the concept on where all things happen
and in what order.
Regards.
> Regards.
> Index:
> RCS file:
> @@ -46,8 +46,12 @@
> SHORTDESCRIPTION,
> //$NON-NLS-1$
> //$NON-NLS-2$
> - DISPLAYNAME,
> resbundle.getString("formattachment.offset"), //$NON-NLS-1$
> - SHORTDESCRIPTION,
> //$NON-NLS-1$
> + DISPLAYNAME,
> + SHORTDESCRIPTION,
> //$NON-NLS-1$
> //$NON-NLS-2$
> + DISPLAYNAME,
> resbundle.getString("formattachment.control"), //$NON-NLS-1$
> + SHORTDESCRIPTION,
> //$NON-NLS-1$
| Re: [Minor Patch] FormAttachmentBeanInfo [message #617351 is a reply to message #145911] |
and in what order.
Regards.
> Regards.
> Index:
> RCS file:
> @@ -46,8 +46,12 @@
> SHORTDESCRIPTION,
> //$NON-NLS-1$
> //$NON-NLS-2$
> - DISPLAYNAME,
> - SHORTDESCRIPTION,
> //$NON-NLS-1$
> + DISPLAYNAME,
> + SHORTDESCRIPTION,
> //$NON-NLS-1$
> //$NON-NLS-2$
> + DISPLAYNAME,
> + SHORTDESCRIPTION,
> //$NON-NLS-1$
Current Time: Thu Nov 06 16:12:33 EST 2025
Powered by FUDForum. Page generated in 0.03103 seconds
