First use impossible [message #145780] |
Fri, 17 October 2003 10:24  |
Originally posted by: pascal_lessard.hotmail.com
I've downloaded the last release of eclipse and installed the java
platform on my computer. When I click on the exe icon after unzipping the
downloaded file, a message box appear and say that there's been na problem
at the startup and that there is a new log file. By the way, I'm not
connected to internet.
The error log that is provided when I click on
> the exe icon is :
> !SESSION
> !ENTRY org.eclipse.core.launcher 4 0 oct. 12, 2003 22:04:27.281
> !MESSAGE Exception launching the Eclipse Platform:
> !STACK
> java.lang.RuntimeException: Could not find bootstrap code. Check location
> of boot plug-in or specify -boot.
> at org.eclipse.core.launcher.Main.searchForBoot(Main.java:468)
> at org.eclipse.core.launcher.Main.getBootPath(Main.java:438)
> at org.eclipse.core.launcher.Main.basicRun(Main.java:281)
> at org.eclipse.core.launcher.Main.run(Main.java:747)
> at org.eclipse.core.launcher.Main.main(Main.java:583)
> !SESSION
> !ENTRY org.eclipse.core.launcher 4 0 oct. 16, 2003 13:44:29.656
> !STACK
> Thank you very much
> Pascal
Re: First use impossible [message #146623 is a reply to message #145975] |
Mon, 20 October 2003 11:56  |
Thank you very much.
John Arthorne wrote:
> This has been reported in the past, and it was a case of unzipping using
> WinZip and not selecting "User folder names". This caused it to unzip
> into a flat directory, and as a result Main couldn't find the plugins
> directory (because there were no directories). Make sure you extract
> from the zip preserving folder names. We are aware the error message is
> not good in this case, and we have a bug report for improving it.
> >>the exe icon is :
> >>!SESSION
> >>!STACK
> >>!SESSION
> >>!STACK
> >>Thank you very much
> >>Pascal
FUDForum. Page generated in 0.03901 seconds
