| custom launch configuration vs. bootclasspath [message #143207] | Wed, 18 February 2004 18:42  |  |
| Eclipse User  |  |  |  |  | Originally posted by: brian_vosburgh.yahoo.com
 I am trying to configure a custom launch configuration that does not use
 the default classpath. I want to add a number of jars that are not used
 during build. But this seems to trigger something in the launcher that
 thinks I want a custom bootclasspath also. I cannot figure out any way to
 stop the launcher from starting my program with a -Xbootclasspath option.
 This causes problems with JCE (I get a NoSuchAlgorithmException when the
 bootclasspath is specified and things work fine when there is no
 bootclasspath specified). Of course, if anyone could tell me how to get
 eclipse to configure my bootclasspath to work with JCE, that would be
 helpful also.
 Thanks.
 Brian
| Re: custom launch configuration vs. bootclasspath [message #143235 is a reply to message #143227] | Wed, 18 February 2004 20:10  |  |
 Thanks, Darin. I am using 2.1.2, and the workaround worked for me. I guess
 I searched the newsgroups for this problem, but not bugzilla. Sorry about
 that.
 Thanks for the quick response.
 Brian
 Darin Swanson wrote:
 > You have found a bug that is fixed in the latest builds of the 3.0 stream.
 > You did not indicated which build you are using (please always do this as it
 > helps us help you), but this has been fixed in builds > M5
 > There is a workarounds listed in the bug report
 > https://bugs.eclipse.org/bugs/show_bug.cgi?id=38370
 > if you do not wish to upgrade (see comment #13)
 > HTH
 > Darins
 > "Brian Vosburgh" <brian_vosburgh@yahoo.com> wrote in message
 > news:c10t8b$660$1@eclipse.org...
 > > helpful also.
 > > Thanks.
 > > Brian
FUDForum. Page generated in 0.05132 seconds
