Home » Archived » DSDP » DSDP/DSF
DSDP/DSF [message #13193] Wed, 09 January 2008 11:59 Go to next message
Originally posted by: jesper.eskilson.iar.com
Hi all,
I'm trying to checkout the DSDP/DSF projects in order to study the
implementations, but I get loads of build errors; things like
"AbstractUIPlugin cannot be resolved".
> Severity and Description Path Resource Location Creation Time Id
> AbstractUIPlugin cannot be resolved org.eclipse.dd.dsf.mi.ui/src/org/eclipse/dd/dsf/mi/ui DsfMIUIPlugin.java line 75 1199895367690 674
I've got a couple of other plugins which work fine, so my Eclipse
installation is not totally broken.
Can anybody give a hint about where I should start looking?
/Jesper
Re: DSDP/DSF build problems [message #13223 is a reply to message #13193] Thu, 10 January 2008 11:32 Go to previous messageGo to next message
The classpath that PDE has for your DSF plugins has might be
broken. Try "PDE Tools > Update classpath". Clean all projects
(without rebuild), close project, reopen project might also
help. You do have a Java 1.5 runtime installed that Eclipse can use?
(Window > Preferences > Java > Installed JREs)
AbstractUIPlugin should definitely be found, so somehow your
PDE / Classpath seems to be broken. I've seen that before on other
plugins, but never quite found what's causing this or how to workaround
it exactly... after some time of trying it eventually worked again.
Also copying the dsdp.dd newsgroup and the dsdp-dd-dev list.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Jesper Eskilson wrote:
> Hi all,
>> Time Id
> /Jesper
Re: DSDP/DSF build problems [message #13251 is a reply to message #13223] Thu, 10 January 2008 15:23 Go to previous messageGo to next message
> help.
No effect.
Yes. Also, the problem appears on both my XP workstation and on my Vista
laptop.
Weird. Well, at the moment I'm just reading code. Lets hope by the time
I need to start hacking things will have fixed themselves. ;-)
/Jesper
Re: DSDP/DSF build problems [message #13278 is a reply to message #13251] Thu, 10 January 2008 16:32 Go to previous message
Hi Jesper,
One thing to keep in mind, DSF HEAD is now dependent on Eclipse 3.4 M4
and CDT 5.0 M4.
-Pawel
>> help.
> No effect.
>> You do have a Java 1.5 runtime installed that Eclipse can use? (Window
> laptop.
>> workaround it exactly... after some time of trying it eventually
>> worked again.
> /Jesper
Re: DSDP/DSF build problems [message #571604 is a reply to message #13193] Thu, 10 January 2008 11:32 Go to previous message
> Hi all,
>> Time Id
> /Jesper
Re: DSDP/DSF build problems [message #571640 is a reply to message #13223] Thu, 10 January 2008 15:23 Go to previous message
> help.
No effect.
laptop.
/Jesper
Re: DSDP/DSF build problems [message #571661 is a reply to message #13251] Thu, 10 January 2008 16:32 Go to previous message
Hi Jesper,
and CDT 5.0 M4.
-Pawel
>> help.
> No effect.
> laptop.
>> worked again.
> /Jesper
Previous Topic:DSDP/DSF
Next Topic:Eclipse Plugin Fest
Current Time: Fri Nov 07 09:28:11 EST 2025
Powered by FUDForum. Page generated in 0.05409 seconds
