Home » Eclipse Projects » Plugin Development Environment (PDE) » eclipse plugin deployment troubleshooting
eclipse plugin deployment troubleshooting [message #1071] Tue, 15 April 2008 11:57 Go to next message
I have a plugin that works from the PDE environment, but when I export
it and deploy it elsewhere, it doesn't work (it has an editor with a
configured extension; it also contributes to the preference page).
I use eclipse 3.4M5 .
Is there a systematic way of debugging this case ?
Re: eclipse plugin deployment troubleshooting [message #1098 is a reply to message #1071] Tue, 15 April 2008 19:31 Go to previous messageGo to next message
Jean-Marc,
I haven't tried this in the 3.4 milestones but in 3.3 you could do the
following:
1) Start Eclipse like the following: eclipse.exe -console
2) Type "ss" in the console to get the 'short status' of all the bundles
starting up
3) Find your plugin in the list and note its bundle number
4) Type "diag <bundle-number>" in the console to see what prerequisites (if
any) are preventing your plugin from starting up.
5) If any plugins are listed that are already in the install, use "diag" to
find out what's preventing them from starting up.
HTH,
Todd
"Jean-Marc Vanel" <jeanmarc.vanel@gmail.com> wrote in message
news:fu2j9g$l2$1@build.eclipse.org...
> Hi
> I have a plugin that works from the PDE environment, but when I export it
Re: eclipse plugin deployment troubleshooting [message #1125 is a reply to message #1098] Wed, 16 April 2008 05:48 Go to previous messageGo to next message
Thanks a lot!
Under the console, "diag" didn't show the problem, but "start" did:
Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.6
The problem was that I compiled in a Java 6 environment, but deployed on
Debian with only Java 5, and I didn't pay attention to this in the
"Overview" tag of my plug-in in PDE:
"specifiy the minimum execution environments required to run this plug-in"
I changed this from J2SE-1.5 to JavaSE-1.6, which entailed this change
in MANIFEST.MF: from
Bundle-RequiredExecutionEnvironment: J2SE-1.5
to:
I redeployed, and IT WORKED !!!!!
Note that the message :
was hard to obtain, and even then, it is not very explicit.
A message like this would be better:
Violated Constraint: bundle XXX declares:
but Execution Environment is: J2SE-1.5 (incompatible with JavaSE-1.6)
Todd Williams wrote:
> Jean-Marc,
> following:
> starting up
> HTH,
> Todd
>>Hi
Re: eclipse plugin deployment troubleshooting [message #1152 is a reply to message #1125] Wed, 16 April 2008 05:57 Go to previous message
Sorry my previous message had reversed the Java versions:
It should read:
I changed this from JavaSE-1.6 to J2SE-1.5, which entailed this change
to:
Re: eclipse plugin deployment troubleshooting [message #565647 is a reply to message #1071] Tue, 15 April 2008 19:31 Go to previous message
Jean-Marc,
following:
starting up
HTH,
Todd
> Hi
Re: eclipse plugin deployment troubleshooting [message #565665 is a reply to message #1098] Wed, 16 April 2008 05:48 Go to previous message
Thanks a lot!
to:
> Jean-Marc,
> following:
> starting up
> HTH,
> Todd
>>Hi
Re: eclipse plugin deployment troubleshooting [message #565682 is a reply to message #1125] Wed, 16 April 2008 05:57 Go to previous message
It should read:
to:
Previous Topic:eclipse plugin deployment troubleshooting
Next Topic:any way to have the batch build generate the p2 descriptor files?
Current Time: Sun Oct 26 01:34:26 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
