Home » Archived » BIRT » XLS Emitter
XLS Emitter [message #139311] Sat, 04 March 2006 14:18 Go to next message
Has anyone gotten the XLS Emitter for BIRT working (can be found here :
http://qauck.wordpress.com/2006/01/24/xlsms-excel-emitter-fo r-birt/) in
the web viewer servlet? I'm running it under JBOSS and would like to be
able to output in XLS..
Any help would be appreciated.
Todd
Re: XLS Emitter [message #140131 is a reply to message #139311] Mon, 06 March 2006 19:31 Go to previous messageGo to next message
Originally posted by: stanguit.hotmail.com
I am wondering about this also. Let me know if you figure it out.
Stan.
Re: XLS Emitter [message #143419 is a reply to message #139311] Mon, 13 March 2006 07:41 Go to previous messageGo to next message
Originally posted by: qauck.msn.com
Todd,
Yes, the XLS emitter should work well under JBOSS as well as other web
containers. But if you're using the default BIRT web viewer, maybe you
need to do some hacking(:)I'm not sure, but the default web viewer
servlet may have restricted the output format as HTML or PDF). I've
added an example on how to integrate the XLS emitter with standalone
Java applications. Just check it out here: http://qauck.blogspot.com .
Hope this helps.
Shawn
> Todd
Re: XLS Emitter [message #143556 is a reply to message #143419] Mon, 13 March 2006 12:20 Go to previous messageGo to next message
Originally posted by: andy.nospam.com
I tried to download it, but got a "You are not permitted to access" message.
Andy
"Shawn Qualia" <qauck@msn.com> wrote in message
news:dv3pcq$rtd$1@utils.eclipse.org...
> Todd,
> need to do some hacking(:)I'm not sure, but the default web viewer servlet
> may have restricted the output format as HTML or PDF). I've added an
> example on how to integrate the XLS emitter with standalone Java
> Hope this helps.
> Shawn
>> Todd
Re: XLS Emitter [message #143645 is a reply to message #143556] Mon, 13 March 2006 21:52 Go to previous messageGo to next message
Please try right click the link and select "save target as...". I myself
sometimes also encounters this problem. Looks may be a problem of the
hosting server. Also I've added an annotation for this in the blog.
> Andy
>> Todd,
>> Hope this helps.
>> Shawn
>>> Todd
Re: XLS Emitter [message #143754 is a reply to message #143645] Tue, 14 March 2006 10:30 Go to previous messageGo to next message
Originally posted by: rebprotizer_2k3.hotmail.com
In fact, there is a problem with Firefox.
In IE, we can use save as... with no problem.
I'm going to test this patch, because I've to do some reports exported to
Excel Files.
Luc LABBE (french developper)
Re: XLS Emitter [message #143759 is a reply to message #143419] Tue, 14 March 2006 11:06 Go to previous messageGo to next message
I have followed the mini tutorial in the web page :
http://qauck.blogspot.com/
but the view as XLS icon has not appeared.
So are steps which I have done :
1. I have downloaded the patch for XLS emitter.
2. I have move the directory of the plugins in my plugins directory of
birt-all-in-one.
3. I have downloaded poi of apache (the version 3.0) and i have put the
poi-3.0-alpha1-20050704.jar in the lib directory of the XLS patch like
this :
C:\Outils
Reporting\Birt\birt-report-all-in-one\plugins\org.uguess.bir t.report.engine.emitter.xls_2.0.0\lib
4. I run my eclipse all in one
So no icon of XLS view has appeared.
What I have forget ?
Thank you for your precious help.
Luc LABBE
Re: XLS Emitter [message #143920 is a reply to message #143759] Wed, 15 March 2006 05:24 Go to previous messageGo to next message
I've found my error. I've forget to replace the three files in precise jar
files.
Now I've got the XLS icon for exporting in this format, but when i'm
clicking on it, I've got this error in the printing viewer : "Error
happened while running the report" in the first cell of the sheet.
I have the same problem with the export to PDF, whereas I have put the
itext jar in the rigth directory.
Thank you for your hopping help
Luc LABBE
Re: XLS Emitter [message #144382 is a reply to message #143920] Wed, 15 March 2006 21:53 Go to previous messageGo to next message
Did you also have the prototype.js in the right place? You can follow
the guideline here: http://www.eclipse.org/birt/phoenix/build/#prototype
And also I myself found some compatibility issues to make the emitter
work with BIRT2.0.1(It works with BIRT2.0.0, but seems 2.0.1 changed
something). I'm trying to put a new package in the blog soon.
> jar files.
> Luc LABBE
Re: XLS Emitter [message #144943 is a reply to message #144382] Fri, 17 March 2006 03:46 Go to previous message
Ok, i'm using the 2.0.1 version, so it's surely why xls emitter doesn't
work.
Thank you for your help and i go to download the 2.0.0 version for trying
it because, I have to do excel report and i have to compare the render
with the jasperreports xls emitter.
I keep an eye on this topic and let me a message when the 2.0.1 version
work on it.
Previous Topic:Generate Word or OpenOffice documents with BIRT
Next Topic:Images in a xml datasource
Current Time: Mon Aug 11 06:08:24 EDT 2025
Powered by FUDForum. Page generated in 0.06436 seconds
