Home » Language IDEs » C / C++ IDE (CDT) » shared source files
shared source files [message #137561] Fri, 04 February 2005 04:40 Go to next message
Originally posted by: nik.cain.neuf.fr
hi again,
my last post reminded me of another question, but I thought I should keep
it in a separate thread.
If several projects share common source code (ie a header file of
definitions), how do I add that to my workspace without creating a project
for it? Or, as an alternative, how do I have each project that uses it
show it in it's own project space, even though the file isn't in the same
folder? (does that make sense?).
thanks,
nik
Re: shared source files [message #137888 is a reply to message #137561] Fri, 04 February 2005 12:40 Go to previous messageGo to next message
Originally posted by: alain.nowhere.ca
Nik wrote:
> hi again,
heu ... try us again with some hardcore details.
Re: shared source files [message #138001 is a reply to message #137888] Sat, 05 February 2005 03:38 Go to previous messageGo to next message
alain wrote:
> Nik wrote:
>> hi again,
>> keep it in a separate thread.
>> project for it? Or, as an alternative, how do I have each project that
>> uses it show it in it's own project space, even though the file isn't
>> in the same folder? (does that make sense?).
ok.
I have three libraries that share a common header file - the header file
has a few definitions and some inline helper funcs that all the
libraries use.
My folder structure is
root -
Common (contains that header)
src for Lib1
src for Lib2
src for Lib3
I have added each Lib as a managed make project, and in the C/C++ I can
see the src for each project, but the common header isn't there. If I
add it myself, it seems I have to add it as a project in its own right,
but I don't want to do that since it's only a header and won't be a lib
etc.
I thought adding a source folder (right click-> New-> Source Folder)
sounded the right thing, but it looks like I can only add folders that
are children of the project folder. Maybe a source folder isn't what I
thought it was (in which case, what is it?).
Ultimately, I want to see the header file in that C/C++ Projects tab so
I can click on it and edit it (I haven't yet seen a way of opening files
in the ide that aren't in the projects list)...
Is that clearer, or still mud like?
thanks,
nik
Re: shared source files [message #138379 is a reply to message #138001] Thu, 10 February 2005 18:16 Go to previous messageGo to next message
Nicholas Cain wrote:
> alain wrote:
>> Nik wrote:
>>> hi again,
> ok.
Sorry for the delay.
> libraries use.
> root -
> src for Lib1
> src for Lib2
> src for Lib3
> etc.
Why not ? Just add it as a std make Project with a Makefile
with empty targets :clean and all.
Or by disabling the builder for the project, see the Builder Property
page.
I simply do not see the resitance of putting the common folder
as a project ... albeit a project will no real builders.
> thanks,
> nik
Re: shared source files [message #138413 is a reply to message #138379] Fri, 11 February 2005 03:24 Go to previous message
>> alain wrote:
>>> Nik wrote:
>>>> hi again,
>>>> that uses it show it in it's own project space, even though the file
>>>> isn't in the same folder? (does that make sense?).
>> ok.
>> file has a few definitions and some inline helper funcs that all the
>> libraries use.
>> root -
>> src for Lib1
>> src for Lib2
>> src for Lib3
>> can see the src for each project, but the common header isn't there.
>> If I add it myself, it seems I have to add it as a project in its own
>> right, but I don't want to do that since it's only a header and won't
>> be a lib etc.
> page.
>> so I can click on it and edit it (I haven't yet seen a way of opening
>> files in the ide that aren't in the projects list)...
>> thanks,
>> nik
oh, of course. Thanks, that makes sense. I'd just assumed every project
had to 'build' something...
many thanks,
nik
Previous Topic:Status of cppunit
Next Topic:Debugger "Launching error"
Current Time: Thu Nov 20 06:02:53 EST 2025
Powered by FUDForum. Page generated in 0.10716 seconds
