Home » Eclipse Projects » Babel » Language packs break Ganymede
Language packs break Ganymede [message #12387] Thu, 26 June 2008 03:25 Go to next message
As soon as I have installed the Ganymede language packs (Englisch, German)
on the Ganymede release (for RCP/Plug-in Developers) it is not possible
any more to install or uninstall any other plugin (e.g. EclipsesNSIS or
Subclipse). The checking for dependencies takes a long time and then the
message "The software item you selected may not be valid with your current
installation..." appears. After uninstalling the German language pack
(this works!) and restarting Eclipse the splash screen flashes every 2
seconds and that's all. I reproduced the problem on a number of different
computers. Does anyone has the same problem?
Frank.
Re: Language packs break Ganymede [message #12397 is a reply to message #12387] Thu, 26 June 2008 04:06 Go to previous messageGo to next message
Originally posted by: godeau_nosp.m_alma.fr
> German) on the Ganymede release (for RCP/Plug-in Developers) it is not
> possible any more to install or uninstall any other plugin (e.g.
> EclipsesNSIS or Subclipse). The checking for dependencies takes a long
> time and then the message "The software item you selected may not be
> valid with your current installation..." appears. After uninstalling the
> German language pack (this works!) and restarting Eclipse the splash
> screen flashes every 2 seconds and that's all. I reproduced the problem
> on a number of different computers. Does anyone has the same problem?
I have exactly the same problem (and some others) with the French
language pack...
Patrick
Re: Language packs break Ganymede [message #12406 is a reply to message #12397] Thu, 26 June 2008 06:24 Go to previous messageGo to next message
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigDCD71833780C1027B1AD61C7
Content-Type: text/plain; charset=UTF-8; format=flowed
Patrick Godeau schreef:
> Le 26/06/2008 09:25, Frank Ulbricht a =C3=A9crit :
>> As soon as I have installed the Ganymede language packs (Englisch,=20
>> German) on the Ganymede release (for RCP/Plug-in Developers) it is not=
=20
>> possible any more to install or uninstall any other plugin (e.g.=20
>> EclipsesNSIS or Subclipse). The checking for dependencies takes a long=
=20
>> time and then the message "The software item you selected may not be=20
>> valid with your current installation..." appears. After uninstalling=20
>> the German language pack (this works!) and restarting Eclipse the=20
>> splash screen flashes every 2 seconds and that's all. I reproduced the=
=20
>> problem on a number of different computers. Does anyone has the same=20
>> problem?
>=20
> I have exactly the same problem (and some others) with the French=20
> language pack...
It seems like I=E2=80=99ve been bitten by this also, but I am not able to=
=20
uninstall the language pack. But then, I didn=E2=80=99t have that messag=
e.
Can I uninstall it by hand?
Cheers, H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.9 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iEYEARECAAYFAkhjbnEACgkQe+7xMGD3itTviACfXOctPqZ3IYd8wyLhpVP8 CF3M
XrAAni5M/xbYT5/sdjX9HhPpTzvxZpQ6
=Waiw
-----END PGP SIGNATURE-----
--------------enigDCD71833780C1027B1AD61C7--
Re: Language packs break Ganymede [message #12415 is a reply to message #12406] Thu, 26 June 2008 08:55 Go to previous messageGo to next message
--------------enig07176D6A377A8FFE524FA620
>>> German) on the Ganymede release (for RCP/Plug-in Developers) it is=20
>>> not possible any more to install or uninstall any other plugin (e.g. =
>>> EclipsesNSIS or Subclipse). The checking for dependencies takes a=20
>>> long time and then the message "The software item you selected may=20
>>> not be valid with your current installation..." appears. After=20
>>> uninstalling the German language pack (this works!) and restarting=20
>>> Eclipse the splash screen flashes every 2 seconds and that's all. I=20
>>> reproduced the problem on a number of different computers. Does=20
>> language pack...
>=20
> It seems like I=E2=80=99ve been bitten by this also, but I am not able =
to=20
> uninstall the language pack. But then, I didn=E2=80=99t have that mess=
age.
>=20
Forget it, I had to be root to do this, since I have no write permission =
where Eclipse is installed.
H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhjkdMACgkQe+7xMGD3itRCogCfd0bpcT8oG64q9DYFrFDf xoGG
b60AniPTXel0dA/dCsD/zkeaVIGToxgi
=tKpr
--------------enig07176D6A377A8FFE524FA620--
Re: Language packs break Ganymede [message #12425 is a reply to message #12415] Thu, 26 June 2008 09:22 Go to previous messageGo to next message
--------------enig2B0790993681D9347C432ADA
>>>> not possible any more to install or uninstall any other plugin (e.g.=
=20
>>>> Eclipse the splash screen flashes every 2 seconds and that's all. I =
>>> language pack...
>> It seems like I=E2=80=99ve been bitten by this also, but I am not able=
to=20
>> uninstall the language pack. But then, I didn=E2=80=99t have that mes=
sage.
>=20
> Forget it, I had to be root to do this, since I have no write permissio=
n=20
But then, it tried to restart and didn=E2=80=99t get past the startup spl=
ash=20
screen. And it disappeared, and came back, disappeared, came back,=20
disappeared, came back=E2=80=A6 I had to kill it with =E2=80=98pkill jav=
a=E2=80=99.
So finally, I had to delete them by hand by doing =E2=80=98rm *nl_nl*=E2=80=
=99 in the=20
eclipse/plugins directory.
Well, this made it a *little* more stable, but it still crashes with=20
multiple segmentation faults after a while.
H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhjmCgACgkQe+7xMGD3itSDeQCeIXSMNYPBVd/PU8etrAY2 knL+
maYAnj5ip7TJ1czI5eX5B2SsvGovepfN
=Ukpx
--------------enig2B0790993681D9347C432ADA--
Re: Language packs break Ganymede [message #12433 is a reply to message #12406] Thu, 26 June 2008 15:59 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
>> language pack...
Do we know what is breaking Eclipse?
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Language packs break Ganymede [message #12437 is a reply to message #12387] Sun, 29 June 2008 13:23 Go to previous messageGo to next message
> Frank.
I have a Ganymede Final installed on a German Windows OS.
Can you explain the steps to reproduce this a little more detailed?
I.e. also the Update URL you used for the German Language Pack.
Was it part of the Ganymede Update site or did you choose one from the
Babel site?
Werner
Re: Language packs break Ganymede [message #12440 is a reply to message #12437] Mon, 30 June 2008 02:01 Go to previous messageGo to next message
Yes I can:
OS: Windows Vista Ultimate, SP1, German, 64 bit
(same problem with (Windows Vista 32Bit, Windows XP SP3)
Java: jdk 1.6 Update 6
1. Unpack of eclipse-rcp-ganymede-win32.zip
2. Start Eclipse and run "Software Updates"
3. Add site:
" http://download.eclipse.org/technology/babel/update-site/gan ymede"
4. Install Englisch and German language packs
5. Restart Eclipse
6. Try to install another plugin (e.g.
http://subclipse.tigris.org/update_1.2.x
7. Message "The software item you selected may not be valid with your
8. Uninstall the language packs
9. Restart Eclipse and you will see the flashing splash screen
Hope, this helps.
Re: Language packs break Ganymede [message #14373 is a reply to message #12440] Mon, 30 June 2008 06:04 Go to previous messageGo to next message
--------------enig87FAF84FC0339A2D18F8F403
Frank Ulbricht schreef:
> Yes I can:
>=20
>=20
> 3. Add site:=20
> 5. Restart Eclipse
> 6. Try to install another plugin (e.g.=20
> 7. Message "The software item you selected may not be valid with your=20
I made a bug for this, having experienced the same problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D238800
H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhor6UACgkQe+7xMGD3itTRCwCeIEwi71JGJmuMIdP2jQmN LKUj
LI4An0UFhphNmR6+nIbhOEAHx+u4IZeb
=VB/R
--------------enig87FAF84FC0339A2D18F8F403--
Re: Language packs break Ganymede [message #14398 is a reply to message #14373] Mon, 30 June 2008 16:51 Go to previous messageGo to next message
Also on Vista?
I'd try replicate this, too, but if somebody did on XP already, then I
would not imagine it to be Vista-specific.
I had a slightly similar issue with WTP and either Subversive or a
similar plugin. Most likely still in Europa, but it may have been
previews of Ganymede.
So from this earlier experience, I doubt it is strictly limited to Babel
either.
W.
>> Yes I can:
>> 3. Add site:
>> 5. Restart Eclipse
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=238800
> H.
Re: Language packs break Ganymede [message #14423 is a reply to message #12387] Wed, 02 July 2008 09:58 Go to previous messageGo to next message
Originally posted by: Uwe.Peuker.bitctrl.de
I have the same problem. I need german translation pack only to export it
into my RCP application.
As a workaround you can start your IDE with the "-nl en_GB" parameter and
all works fine.
Uwe
"Frank Ulbricht" <f.ulbricht@qualitype.de> schrieb im Newsbeitrag
news:bf5c7eae369821c961885fbf6a1458a4$1@www.eclipse.org...
> Frank.
Re: Language packs break Ganymede [message #14601 is a reply to message #14398] Fri, 04 July 2008 10:05 Go to previous messageGo to next message
Originally posted by: christian.klemke.irisgmbh.de
Hi everyone.
I can confirm that the problem also fully exists on Win XP:
After installation of the German translations, it's impossible to add
additional features due to missing constraint errors.
Uninstalling the language pack results in the flashing splash screen
described before (by the way, the task manager shows that the process id
changes every time, so the flashing is caused by an endless sequence of
eclipse.exe restarts !)
After killing the process and restarting eclipse.exe with the -clean command
line option, everything works fine again (eclipse starts up correctly and
installation of new features works again.)
Well, actually there is another oddity: for my installation test I chose the
Java EE Development feature. The installation wizard shows an *empty* list
on the first page ("Install"), but indicates a total size of about 70 MB.
The second page on the other hand ("Review licenses") show all plugins. This
is probably an unrelated effect, but the whole thing is kind of strange
anyway...
Hope that helps.
Christian
"Werner Keil" <werner.keil@gmx.net> schrieb im Newsbeitrag
news:g4bgvl$via$1@build.eclipse.org...
> Also on Vista?
> I had a slightly similar issue with WTP and either Subversive or a similar
> plugin. Most likely still in Europa, but it may have been previews of
> Ganymede.
> either.
> W.
>>> Yes I can:
>>> 3. Add site:
>>> 5. Restart Eclipse
>> H.
Re: Language packs break Ganymede [message #14632 is a reply to message #14601] Fri, 04 July 2008 11:14 Go to previous messageGo to next message
--------------010401020902020004090109
I managed to install the translated Strings for my language *and* keep
being able to install new features, but it remains rather tedious. With
a ganymede installation :
1 - install babel for your language
2 - try and install a new feature, the list of all features with
unresolved dependencies appear on the lower half of the dialog that pops up
3 - retrieve the list of all these *nl_<country code> features and
remove them from your eclipse "plugins" dir
4 - remove the latest file in the
" p2/org.eclipse.equinox.p2.engine/profileRegistry/SDKProfile. profile "
directory of your eclipse installation
Now you have the translated Strings and you can add new features. Of
course, this also means you won't have the translated String for the
features you add later on ...
There may be an easier way of achieving this, but at least it allows us
to install babel translations.
Cheers
Laurent Goubet
Obeo
iris Christian Klemke a
Re: Language packs break Ganymede [message #16462 is a reply to message #12433] Fri, 11 July 2008 14:20 Go to previous message
I had problems importing existing projects into a new workspace. It was
a problem in German translations, that prevents PDE from importing.
I corrected those erroneous translations, but I think Babel should check
translations beforehand.
Marco
>>> language pack...
Re: Language packs break Ganymede [message #571015 is a reply to message #12387] Thu, 26 June 2008 04:06 Go to previous message
language pack...
Patrick
Re: Language packs break Ganymede [message #571082 is a reply to message #12397] Thu, 26 June 2008 06:24 Go to previous message
=20
=20
=20
>> problem?
>=20
> language pack...
=20
e.
Cheers, H.
--=20
Hendrik Maryns
http://aouw.org
=Waiw
Re: Language packs break Ganymede [message #571144 is a reply to message #12406] Thu, 26 June 2008 08:55 Go to previous message
>> language pack...
>=20
to=20
age.
>=20
H.
--=20
Hendrik Maryns
http://aouw.org
=tKpr
Re: Language packs break Ganymede [message #571227 is a reply to message #12415] Thu, 26 June 2008 09:22 Go to previous message
=20
>>> language pack...
to=20
sage.
>=20
n=20
ash=20
a=E2=80=99.
=99 in the=20
H.
--=20
Hendrik Maryns
http://aouw.org
=Ukpx
Re: Language packs break Ganymede [message #571248 is a reply to message #12406] Thu, 26 June 2008 15:59 Go to previous message
>> language pack...
Re: Language packs break Ganymede [message #571271 is a reply to message #12387] Sun, 29 June 2008 13:23 Go to previous message
> Frank.
Babel site?
Werner
Re: Language packs break Ganymede [message #571294 is a reply to message #12437] Mon, 30 June 2008 02:01 Go to previous message
Yes I can:
3. Add site:
5. Restart Eclipse
Hope, this helps.
Re: Language packs break Ganymede [message #571364 is a reply to message #12440] Mon, 30 June 2008 06:04 Go to previous message
> Yes I can:
>=20
>=20
> 3. Add site:=20
> 5. Restart Eclipse
H.
--=20
Hendrik Maryns
http://aouw.org
=VB/R
Re: Language packs break Ganymede [message #571386 is a reply to message #14373] Mon, 30 June 2008 16:51 Go to previous message
Also on Vista?
either.
W.
>> Yes I can:
>> 3. Add site:
>> 5. Restart Eclipse
> H.
Re: Language packs break Ganymede [message #571419 is a reply to message #12387] Wed, 02 July 2008 09:58 Go to previous message
all works fine.
Uwe
> Frank.
Re: Language packs break Ganymede [message #571637 is a reply to message #14398] Fri, 04 July 2008 10:05 Go to previous message
Hi everyone.
anyway...
Hope that helps.
Christian
> Also on Vista?
> Ganymede.
> either.
> W.
>>> Yes I can:
>>> 3. Add site:
>>> 5. Restart Eclipse
>> H.
Re: Language packs break Ganymede [message #571660 is a reply to message #14601] Fri, 04 July 2008 11:14 Go to previous message
Cheers
Laurent Goubet
Obeo
Re: Language packs break Ganymede [message #572179 is a reply to message #12433] Fri, 11 July 2008 14:20 Go to previous message
Marco
>>> language pack...
Previous Topic:Import properties file into babel server
Next Topic:Find strings for translation
Current Time: Wed Nov 19 23:37:37 EST 2025
Powered by FUDForum. Page generated in 0.15550 seconds
