Home » Language IDEs » ServerTools (WTP) » EJB without xdoclet
EJB without xdoclet [message #134549] Tue, 23 August 2005 21:49 Go to next message
Is there a way to build and EJB without xdoclet support? I am workign with
and older, but large set of EJB's without xdoclet. (manually maintain
ejb-jar.xml and jboss releated deployment artifacts).
Re: EJB without xdoclet [message #134601 is a reply to message #134549] Wed, 24 August 2005 09:42 Go to previous message
1.) Turn off xdoclet builder in the properties of the project, page
builder.
or 2.) if you want to use xdoclet partly:
Look into the ant file for the xdoclet build.
Inside it is explained how to merge the xdoclet contents with external
xml files.
Previous Topic:Deployment to Jboss as folder
Next Topic:Facelets xhtml support in WTP
Current Time: Fri Oct 24 14:43:41 EDT 2025
Powered by FUDForum. Page generated in 0.06921 seconds
