Home » Eclipse Projects » GEF » control which items can be parents for new items 'clicked' rather than dragged from the palette
control which items can be parents for new items 'clicked' rather than dragged from the palette [message #134086] Tue, 25 May 2004 10:15 Go to next message
Originally posted by: evanlinwood.hotmail.com
When I click on an item in the palette, and then hover over items in my
model, I want to be able to selectively determine which types of items
(already present in the model) will accept the new item as a child, and
which will not (in which case the cursor should turn into a stop-sign).
I've managed to implement isEnabled() OK on a subclassed
TemplateTransferDropTargetListener such that when I drag an item off the
palette, I can selectively determine which types of editparts I can drop it
onto. (The cursor turns into a stop-sign for those I don't want it to be
possible to drop into).
I've also managed to control 'dragging' of existing items already in the
model with respect to which types of new parents they can be dropped onto
using isTargetLocked() in a DragEditPartsTracker(). I haven't been able to
figure out how to get the stop-sign cursor to appear in this case.
If anybody can suggest how to solve in particular the first case, your help
would be greatly appreciated!
Evan
Re: control which items can be parents for new items 'clicked' rather than dragged from the palette [message #134260 is a reply to message #134086] Tue, 25 May 2004 17:05 Go to previous message
You shouldn't be using isTargetLocked probably. Indication of not allowed
is done by Command.isExecutable(). The exception is drop targets, which do
not attempt to obtain a command because the item being dropped is not always
available during hte dragover callbacks.
"Evan Linwood" <evanlinwood@hotmail.com> wrote in message
news:c8vk6t$eju$1@eclipse.org...
it
to
help
> Evan
Previous Topic:Connection end labels + feedback
Next Topic:Problem with ComboBox Property Descriptor
Current Time: Wed Nov 05 20:21:04 EST 2025
Powered by FUDForum. Page generated in 0.04783 seconds
