Home » Language IDEs » C / C++ IDE (CDT) » Using CDT with another compiler (not gcc)
Using CDT with another compiler (not gcc) [message #133216] Mon, 03 January 2005 03:24 Go to next message
Originally posted by: levw.mail.ru
Can I use Eclipse CDT on Solaris with Sun's C++ compiler?
Re: Using CDT with another compiler (not gcc) [message #133242 is a reply to message #133216] Mon, 03 January 2005 07:12 Go to previous messageGo to next message
I don't think the Managed Make project in CDT supports Sun C++ compiler
out of the box, but if it's a close enough to GCC I don't see why you
can't get it to work, you will probably need to edit the different
variables and flags to match your compiler.
In the worse case scenario you can always create a Standard Make project
in CDT and use your own tools to generate a Makefile for your project.
PS: CDT only support GDB debugger for now, so if you compile your
project with anything other than GCC you might not be able to use
eclipse to debug it.
Gael
Re: Using CDT with another compiler (not gcc) [message #133298 is a reply to message #133242] Tue, 04 January 2005 02:33 Go to previous messageGo to next message
Does CDT have a parser for binaries built by Sun's compiler?
> Gael
Re: Using CDT with another compiler (not gcc) [message #133311 is a reply to message #133298] Tue, 04 January 2005 03:25 Go to previous message
If Sun C++ compiler generates ELF binaries I guess it would work, you
would have to try, these are the parser available in CDT 2.1:
-Elf
-PE Windows
-HP-UX SOM
-AIX XCOFF32
-GNU Elf
-Cygwin PE
-Mach-O
Gael
Previous Topic:new class template violates 17.4.3.1.2
Next Topic:CDT Plug-in for Microsoft Debugger?
Current Time: Sat Nov 08 13:45:48 EST 2025
Powered by FUDForum. Page generated in 0.03134 seconds
