Home » Language IDEs » ServerTools (WTP) » web server ports
web server ports [message #132075] Thu, 11 August 2005 18:56 Go to next message
Originally posted by: mjackson.cdi-hq.com
I'm trying to figure out how to change the port that eclipse is starting
my copy of tomcat on. I've configured the http port to be port 80, but
when it's started by eclipse it comes up on port 8080. Where is 8080
coming from? Does eclipse override the entries in the server.xml file?
Re: web server ports [message #132213 is a reply to message #132075] Fri, 12 August 2005 03:18 Go to previous messageGo to next message
Originally posted by: zf_soaring.yahoo.com.cn
Eclipse save a copy of tomcat configuration in the directory
\workspace\Servers\Tomcat v5.0 Server @ localhost-config.
Find the web.xml file int that directory and the change the port settings in
that file
"Mike Jackson" <mjackson@cdi-hq.com>
??????:b305a66b119ce1cd5415ee8497d2a4a1$1@www.eclipse.org...
Re: web server ports [message #132290 is a reply to message #132213] Fri, 12 August 2005 08:41 Go to previous messageGo to next message
I believe the file you want to modify is server.xml. You can edit this
file directly, or right-click on the server in the Servers view and
select Open. In the Ports section of the Server Overview, click on port
you want to change and modify it. Then save the configuration.
Larry
> that file
Re: web server ports [message #132329 is a reply to message #132290] Fri, 12 August 2005 09:27 Go to previous messageGo to next message
You are right.
I am sorry for that mistake.
Thanks for you.
Eric
"Larry Isaacs" <Larry.Isaacs@sas.com>
??????:ddi5el$3ur$1@news.eclipse.org...
>file directly, or right-click on the server in the Servers view and select
>Open. In the Ports section of the Server Overview, click on port you want
> Cheers,
> Larry
>> in that file
Re: web server ports [message #132434 is a reply to message #132329] Fri, 12 August 2005 11:44 Go to previous messageGo to next message
I found the server.xml under the servers folder in my workspace and
changed it. I tried the ports thingy first, but couldn't figure out how
to change ports (I assume you ment the monitored ports?). Thanks for the
assist.
Re: web server ports [message #132588 is a reply to message #132434] Fri, 12 August 2005 23:58 Go to previous message
Now you can try the way Larry Isaacs mentioned above,because that's a
convenient way.
Right-click on the server in the server view and select open.
Then you can edit some configuration of the server directly,save it and
restart the server(if necessary).
Thanks for Larry .
Eric
??????:ee643d9131bf020c9c02c43d426c7474$1@www.eclipse.org...
>I found the server.xml under the servers folder in my workspace and changed
>it. I tried the ports thingy first, but couldn't figure out how to change
>ports (I assume you ment the monitored ports?). Thanks for the assist.
Previous Topic:sun license agreement on new ejb project
Next Topic:Do DB Tools work at all on Mac OS X?
Current Time: Sun Nov 23 08:59:43 EST 2025
Powered by FUDForum. Page generated in 0.04436 seconds
