Home » Language IDEs » ServerTools (WTP) » RDB component invisible!
RDB component invisible! [message #130076] Fri, 05 August 2005 06:50 Go to next message
I have downloaded and installed wtp-all-in-one-0.7-win32.zip and want to
test the 'rdb' component.
But I don't have any view under the "Server Explorer Category".
This category doesn't even exist.
On the other side, I have the 'Servers' view under the Server category,
but I don't think it is related to 'rdb'.
I have the org.eclipse.wst.rdb.* plugins installed and loaded as reported
in Help About.
I haven't seen no relevant errors in the log.
What could be wrong?
Thanks in advance for any suggestion.
Re: RDB component invisible! [message #130199 is a reply to message #130076] Fri, 05 August 2005 10:16 Go to previous messageGo to next message
See the Data category, it has Database explorer and DataOutput View
Re: RDB component invisible! [message #130211 is a reply to message #130199] Fri, 05 August 2005 10:38 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
I have wtp-all-in-one-0.7-win32 installed. In the Preferences I see only
- 'Data'. Has only two buttons 'Restore Defaults' and 'Apply' and
nothing else.
- 'Label Decorations'
- 'Output'
Should there be more?
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: RDB component invisible! [message #130303 is a reply to message #130211] Fri, 05 August 2005 14:37 Go to previous messageGo to next message
Go to Windows->Show View->Other..., look for Data section
Re: RDB component invisible! [message #130705 is a reply to message #130199] Mon, 08 August 2005 03:13 Go to previous messageGo to next message
Thanks.
I know see the views!!
But I'm missing the ability to edit the connection properties.
For each connection I have to specify the main class and jars location.
Possibly, it would be better to define the available drivers just once.
I'm working with Informix, it says it connects ok but I don't see any
table.
Re: RDB component invisible! [message #131141 is a reply to message #130705] Tue, 09 August 2005 07:29 Go to previous messageGo to next message
Originally posted by: jens.ja-web.de
> table.
Yes, same with MySQL-4 and MSSqlServer: (
Re: RDB component invisible! [message #133211 is a reply to message #131141] Wed, 17 August 2005 09:57 Go to previous messageGo to next message
And is there any work around?
Re: RDB component invisible! [message #134210 is a reply to message #133211] Mon, 22 August 2005 13:16 Go to previous message
Originally posted by: stoeckelmann.web.de
I use mysql-4.0.25 (win32) and I see tables! But no columns!
I tried "derby 10" as well and everthing is working fine.
I'm a bit disappointed with the RDB tool and now use the small "clay"
plugin (no eclipse project) for modelling und exploring databases with
mysql.
Previous Topic:WST/JST/Tomcat 5.5.9/Java 1.5 Questions
Next Topic:What is the difference ????
Current Time: Sat Nov 08 04:36:45 EST 2025
Powered by FUDForum. Page generated in 0.04624 seconds
