Home » Language IDEs » ServerTools (WTP) » EJB Project using wtp-all-in-one-0.7-win32
EJB Project using wtp-all-in-one-0.7-win32 [message #129143] Tue, 02 August 2005 15:12 Go to next message
Originally posted by: weconsul.ptd.net
I was trying to help someone, in this newsgroup, using the WTP Tutorial
'Building a Simple EJB Application'. I figured I would try it myself.
I have jboss-4.0.2 but, for this tutorial, I downloaded jboss-3.2.3 to
match the JBoss 3.2.3 generic installed runtime server. I then define
the JBoss 3.2.3 generic serer and selected it.
Problem in the 'WTP Tutorial - Building a Simple EJB Application' I do
the following.
- right-click on EJB Projects and load that new EJB Project wizard
- Enter 'ZooBeans' for the project name
- Select 'Show Advanced'
- Nothing displays in the 'Target Server' dropdown even thought I did
define the jboss-3.2.3 Generic runtime Server.
- OK, so I select 'new' and redefined a jboss-3.2.3 Generic server
Problem is, after doing this, the 'Target Server' dropdown never gets
populated with the defined runtime server. I do see this new jboss-3.2.3
Generic runtime Server in the Server preferences.
I figured this would be fixed in the final wtp-all-in-one-0.7
Are there any ids so I can run tis tutorial and naturally use it to
develop an EJB Application
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: EJB Project using wtp-all-in-one-0.7-win32 [message #129329 is a reply to message #129143] Tue, 02 August 2005 21:57 Go to previous messageGo to next message
Your jboss is not displayed since the servers are filtered based on
version, if you change the EJB version to 2.0, since that is the latest
EJB version which JBoss 3.2.3 supports i expect that you would see JBoss
selected
Re: EJB Project using wtp-all-in-one-0.7-win32 [message #129342 is a reply to message #129329] Tue, 02 August 2005 22:24 Go to previous message
> selected
Thanks for you help.
Previous Topic:Is DynamicWebPorject-the-only-Way ??
Next Topic:Problems creating new XSLT files
Current Time: Wed Nov 05 19:20:17 EST 2025
Powered by FUDForum. Page generated in 0.03186 seconds
