| Eclipse, BIRT, Oracle data set exception [message #126863] |
Fri, 30 December 2005 09:46  |
Originally posted by: segoetz.sbcglobal.net
I have installed Eclipse 3.1.1 Win 32, and BIRT 1.0.1
Doing a tutorial, I was able to create a new report using the sample
database, Classic Models, for my data source. I can preview the data set I
created, and can see the data in the report when I preview it.
I have set up two data sources to Oracle databases and get successful
connection when I click test connection. When I set up a data set for
either and try to open it, I get the error An unexpected internal
exception occurred. Please see log for detail. The log says
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID rg.eclipse.birt.report.designer.ui
Version:1.0.1
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.NullPointerException
Ive tried to set up my paths correctly. Can anyone help? Thanks.
FUDForum. Page generated in 0.08676 seconds
