Home » Archived » Visual Editor (VE) » IWAV0177E Expression 'xxx' is too complicated
IWAV0177E Expression 'xxx' is too complicated [message #126561] Tue, 20 June 2006 17:30 Go to next message
My composite has a setter that accepts an object of Class A. VE doesn't seem to invoke this setter,
I got this message "IWAV0177E Expression 'xxx' is too complicated". Other setters that have
arguments of primitive classes are OK.
Does anyone know how to get around this problem? Thanks.
Re: IWAV0177E Expression 'xxx' is too complicated [message #126574 is a reply to message #126561] Tue, 20 June 2006 17:33 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
It doesn't stop things from working, it just won't apply it to the
object during VE editing. It will still work fine.
If you are at VE 1.1.0.1 or lower we don't handle expressions that refer
to members or methods of the class that are not beans that we know about
(i.e. the visuals). In VE 1.2 we do a better job of this and can
handle more types of expressions.
The standard expressions in VE 1.1.0.1 that are not too complicated are
calls to static methods, primitives, strings, constructors.
Hung wrote:
> Hello,
> seem to invoke this setter, I got this message "IWAV0177E Expression
Rich Kulp
Re: IWAV0177E Expression 'xxx' is too complicated [message #126643 is a reply to message #126574] Tue, 20 June 2006 23:01 Go to previous messageGo to next message
Hello Rich,
Thanks for the response. I am using VE 1.2 RC1. Our composite depends on
that value for rendering during VE editing and runtime, if the value is not applied during
VE editing, our composite doesn't display anything. Is there guidelines on how to convert
this expression to something that can be handled by VE during editing? Thanks.
> (i.e. the visuals). In VE 1.2 we do a better job of this and can handle
> Hung wrote:
>> Hello,
>> doesn't seem to invoke this setter, I got this message "IWAV0177E
Re: IWAV0177E Expression 'xxx' is too complicated [message #126669 is a reply to message #126643] Wed, 21 June 2006 10:13 Go to previous message
There are no general rules. It tries as best it can. Can you put a
snippet here to show what the expression looks like?
Hung wrote:
> Hello Rich,
> not applied during
> on how to convert
Rich Kulp
Re: IWAV0177E Expression 'xxx' is too complicated [message #613376 is a reply to message #126561] Tue, 20 June 2006 17:33 Go to previous message
Hung wrote:
> Hello,
Rich Kulp
Re: IWAV0177E Expression 'xxx' is too complicated [message #613381 is a reply to message #126574] Tue, 20 June 2006 23:01 Go to previous message
Hello Rich,
> Hung wrote:
>> Hello,
Re: IWAV0177E Expression 'xxx' is too complicated [message #613383 is a reply to message #126643] Wed, 21 June 2006 10:13 Go to previous message
Hung wrote:
> Hello Rich,
> not applied during
> on how to convert
Rich Kulp
Previous Topic:Access by method name (xxxxx) (not by proxy) requires a receiver.
Next Topic:Access by method name (xxxxx) (not by proxy) requires a receiver.
Current Time: Mon Nov 17 05:15:51 EST 2025
Powered by FUDForum. Page generated in 0.04139 seconds
