Home » Language IDEs » Java Development Tools (JDT) » Step Filtering
Step Filtering [message #125368] Mon, 08 December 2003 20:31 Go to next message
Originally posted by: newbie.spam.com
I have a step filter defined as "org.apache.*", but when I Step with
Filters I keep getting "Source not found" because Eclipse is looking for
org.apache.struts.action.ActionServlet's source. How do I filter this out?
Re: Step Filtering [message #125515 is a reply to message #125368] Tue, 09 December 2003 09:33 Go to previous messageGo to next message
I need more specific details to understand the problem you are having. The
"step with filters" action performs continuous "step into's" until a
non-filterd location is encountered.
Darin
"newbie" <newbie@spam.com> wrote in message news:br38lu$i8n$1@eclipse.org...
out?
Re: Step Filtering [message #128015 is a reply to message #125515] Tue, 16 December 2003 23:17 Go to previous messageGo to next message
I don't want to see the source for any classes under org.apache.*, but
when I Step with Filters the Debugger keeps stopping with this in the
editor:
Class File Editor
Source not found
The jar file struts.jar has no source attachment.
You can attach the source by clicking Attach Source below:
Why am I seeing this if org.apache.* is defined as a filter?
> Darin
> out?
Re: Step Filtering [message #128580 is a reply to message #128015] Thu, 18 December 2003 13:33 Go to previous messageGo to next message
"Stepping with filters" performs a "step into" at the current location until
the resulting location in non-filtered.
How do you end up at the location you describe? breakpoint? exception? step
over?
Darin
"newbie" <newbie@spam.com> wrote in message news:brolc1$7v1$1@eclipse.org...
> editor:
> Class File Editor
> Source not found
The
> > Darin
for
> > out?
Re: Step Filtering [message #128647 is a reply to message #128580] Thu, 18 December 2003 21:24 Go to previous messageGo to next message
A breakpoint is set on a class that uses Struts, but a breakpoint is not
set on the Struts class. It's not in an exception and not a step
over--just a Step with Filters. I have the same behavior with weblogic
classes. I've defined a "weblogic.*" filter. Yet the debugger will stop
with the message below because it's looking for WebLogic source. Isn't
anyone else having this problem? I've been seeing it on different
versions of Eclipse from 2.0 through 3.0M5.
> over?
> Darin
> > editor:
> > Class File Editor
> > Source not found
> The
> > > Darin
> for
> > > out?
Re: Step Filtering [message #128660 is a reply to message #128647] Thu, 18 December 2003 22:58 Go to previous message
You should file a bug report with a simple example that demostrates the
problem. It may be a bug, or it may be that step filters are not working the
way you assume they should.
Darin
"newbie" <newbie@spam.com> wrote in message news:brtnhh$qh8$1@eclipse.org...
until
step
> > over?
> > Darin
> > > editor:
> > > Class File Editor
> > > Source not found
having.
> > The
> > > > Darin
with
looking
> > for
this
> > > > out?
Previous Topic:external cvs update + refresh = problems.
Next Topic:Refactoring: add new refactoring
Current Time: Wed Nov 05 03:28:36 EST 2025
Powered by FUDForum. Page generated in 0.04594 seconds
