| Re: [Teneo] GMF Editors [message #123217] |
Wed, 02 May 2007 07:20  |
James,
I guess no one has experience with this. Let me try adding the GMF
newsgroup to the list, since it's more likely that someone with
experience will see this post there. I know that Dave from my group
made an EMF generated editor work with Teneo and he said is was very
trivial involving only the addition of some configuration code to
register the right things...
James Willans wrote:
> I'm exploring technology for collaborative modelling using EMF
> models. I've been looking at Teneo with interest, particularly the
> Resource Utility which eliminates the need to store any data locally.
> I'm interested to know whether anyone has experimented using GMF
> models with the Resource Utility so that both the EMF model and the
> GMF diagrams over the model are stored only within the database and
> not on the file system?
> James
| Re: [Teneo] GMF Editors [message #123368 is a reply to message #123290] |
Wed, 02 May 2007 08:26  |
We store GMF diagrams as blob [byte array] in database.
If some more information is needed then may be we will jot down
something and can post later next week.
- Parvez Chauhan
Martin Taal wrote:
> Hi James,
> Sorry I had missed your post. About 6 months back I have tried myself to
> also store the diagram into the db but at that time ran into problems
> because the gmf model itself extends the ecore model and because of this
> issue:
> http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg02482.html
> I do not know if this has changed.
> Also at that time Teneo did not support the features of the ecore model.
> The current 0.8.0 release of Teneo however has better support. So it can
> be worth a try.
> Regarding gmf see also the recent thread on this newsgroup with the title:
> [Teneo]Problem Persisting GMF diagram to HibernateResource
> gr. Martin
> Ed Merks wrote:
>> James,
>>> locally. I'm interested to know whether anyone has experimented
>>> using GMF models with the Resource Utility so that both the EMF model
>>> and the GMF diagrams over the model are stored only within the
>>> database and not on the file system?
>>> James
FUDForum. Page generated in 0.04427 seconds
