Home » Archived » BIRT » controling the order of Y series grouping (and legend) of a stacked bar chart
controling the order of Y series grouping (and legend) of a stacked bar chart [message #122354] Wed, 01 February 2006 00:38 Go to next message
Originally posted by: rrachamallu.hotmail.com
I have stacked bar chart, with location names for Category(X) Series,
Percentage values for Value(Y) Series. The Optional Y Series Grouping is on
an attribute which can have values of 'High', Medium' and 'Low'.
The problem I have is that, whatever I do, the Y series groupings (and the
legend) are grouped as 'High', 'Low' and 'Medium'. It appears that the Y
series grouping values are being alphabetically sorted.
Is there anyway through which I can have the groupings show up as 'High',
'Medium' and 'Low' instead of 'High', 'Low' and 'Medium'? Any help will be
greatly appreciated.
Reddy
Re: controling the order of Y series grouping (and legend) of a stacked bar chart [message #125606 is a reply to message #122354] Tue, 07 February 2006 16:31 Go to previous messageGo to next message
I found a workaround for this problem and wanted to share the workaround. If
you have a better way of doing this, please let me know.
I changed my query so that 'High' mapped to 1, 'Medium' mapped to 2 and
'Low' mapped to 3. With this the legend shows up in order (1, 2, 3).
I then implemented the 'beforeDrawLegendEntry' callback method.
function beforeDrawLegendEntry( label, context )
var labelValue = label.getCaption().getValue();
if(labelValue == 1) label.getCaption().setValue("High");
if(labelValue == 2) label.getCaption().setValue("Medium");
if(labelValue == 3) label.getCaption().setValue("Low");
This did the trick for me. The legend in my report now shows up as 'High',
'Medium', 'Low' in that order.
Reddy
"Reddy Rachamallu" <rrachamallu@hotmail.com> wrote in message
news:drph72$cm4$1@utils.eclipse.org...
> on an attribute which can have values of 'High', Medium' and 'Low'.
> the legend) are grouped as 'High', 'Low' and 'Medium'. It appears that the
> Y series grouping values are being alphabetically sorted.
> Thanks
> Reddy
Re: controling the order of Y series grouping (and legend) of a stacked bar chart [message #168550 is a reply to message #125606] Thu, 08 June 2006 11:19 Go to previous messageGo to next message
This workaround doesn't work so well in that the Legend does not
increase in size to accommodate labels longer in length than the
original "1", "2", and "3" labels.
> Thanks
> Reddy
>> Thanks
>> Reddy
Re: controling the order of Y series grouping (and legend) of a stacked bar chart [message #168964 is a reply to message #168550] Sun, 11 June 2006 01:21 Go to previous message
George,
How about using aHigh, bMedium and cLow. And then use the script to
remove the first letter. This should make sure
the labels are has enough space.
Carsten
>> workaround. If you have a better way of doing this, please let me know.
>> and 'Low' mapped to 3. With this the legend shows up in order (1, 2, 3).
>> 'High', 'Medium', 'Low' in that order.
>> Thanks
>> Reddy
>>> Hi,
>>> Series, Percentage values for Value(Y) Series. The Optional Y Series
>>> Grouping is on an attribute which can have values of 'High', Medium'
>>> and 'Low'.
>>> (and the legend) are grouped as 'High', 'Low' and 'Medium'. It
>>> appears that the Y series grouping values are being alphabetically
>>> sorted.
>>> 'High', 'Medium' and 'Low' instead of 'High', 'Low' and 'Medium'? Any
>>> help will be greatly appreciated.
>>> Thanks
>>> Reddy
Previous Topic:v2.1 RC4 - Preview as PDF drops .pdf extension
Next Topic:runtime.jar not found
Current Time: Sat Nov 08 11:07:12 EST 2025
Powered by FUDForum. Page generated in 0.03164 seconds
