Home » Newcomers » Newcomers » running RCP client sample
running RCP client sample [message #122347] Wed, 07 December 2005 19:57 Go to next message
Originally posted by: datatronics.verizon.net
I recently installed Eclipse 3.1 and tried to create and run
"Hello RCP" demo from
http://eclipse.org/articles/Article-RCP-1/tutorial1.html
I receive ERROR:
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could
not be found in the registry. The applications available are: <NONE>.
might someone be able to explain why the demo doesn't function?
Re: running RCP client sample [message #122382 is a reply to message #122347] Wed, 07 December 2005 23:38 Go to previous message
>>>> could not be found in the registry. The applications available are:
<NONE>.
the error seems to result from my opening of Eclipse
specifying a workspace other then the
Eclipse installation directory
which brings 2 new questions to mind:
is it possible to specify project workspaces
other then the Eclipse installation directory,
some sort of redirection .xml file?
what problems might I encounter from trying to
move the entire Eclipse installation to another directory location?;
I don't see any un-install program,
and I don't see Eclipse listed in Windows XP SP2 control panel
"add/remove programs"
is it possible to simply move the entire Eclipse installation to a new
directory location,
or to simply delete the current installation and re-install?
are there windows registry entries which would cause problems?
Previous Topic:Failed to start Infocenter(Help System)
Next Topic:Eclipse install
Current Time: Sat Nov 22 17:17:04 EST 2025
Powered by FUDForum. Page generated in 0.10856 seconds
