Home » Modeling » GMF (Graphical Modeling Framework) » Passing the diagram filename to a model element property ??
Passing the diagram filename to a model element property ?? [message #122248] Fri, 27 April 2007 08:26 Go to next message
Originally posted by: renwart.lippmann.lu
Hi everybody,
I'd like to get the filename (and if possible the full path) of a
diagram and assign it to a property ("name") of my model element...
Thanks in advance for any help.
benren.
Re: Passing the diagram filename to a model element property ?? [message #122259 is a reply to message #122248] Fri, 27 April 2007 08:36 Go to previous messageGo to next message
Originally posted by: angelo.marguglio.eng.it
Hi! You can use this code:
FileDiagramEditor editor = (FileDiagramEditor)
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePag().getActiveEditor();
editor.getEditorInput();
From this object you can find what you want!
BYE
"Ben Renwart" <renwart@lippmann.lu> ha scritto nel messaggio
news:f0sq2o$9go$1@build.eclipse.org...
> Hi everybody,
> I'd like to get the filename (and if possible the full path) of a diagram
> benren.
Re: Passing the diagram filename to a model element property ?? [message #122271 is a reply to message #122248] Fri, 27 April 2007 08:37 Go to previous messageGo to next message
Hi Ben,
org.eclipse.emf.workspace.util.WorkspaceSynchronizer.getFile (diagram.eResource())
will give you the IFile that stores the diagram.
Boris
Ben Renwart wrote:
> Hi everybody,
> benren.
Re: Passing the diagram filename to a model element property ?? [message #122315 is a reply to message #122271] Fri, 27 April 2007 10:12 Go to previous messageGo to next message
Originally posted by: bagnard.natacha.free.fr
Hi Boris,
I'm really interested by the tips you give here but I don't know how you
get your diagram object. I searched for it but can't find it.
Could you explain me how you get it ?
Natacha
Boris Blajer a écrit :
> Hi Ben,
> Best regards,
> Boris
Re: Passing the diagram filename to a model element property ?? [message #122359 is a reply to message #122315] Fri, 27 April 2007 11:26 Go to previous messageGo to next message
Hi Natacha,
I interpreted the question "I'd like to get the filename of a
diagram..." as an indication of the fact that the diagram is available.
If you only have an IEditorPart, you may cast it to
IDiagramWorkbenchPart and use IDiagramWorkbenchPart#getDiagram() method.
If you only have a GraphicalViewer, you may use
graphicalViewer.getContents().getModel() and cast the result to Diagram.
Otherwise, it's not so easy to give advice without knowing what you
start with :)
Boris
natacha bagnard wrote:
> Hi Boris,
> Natacha
>> Hi Ben,
>> Best regards,
>> Boris
Re: Passing the diagram filename to a model element property ?? [message #123303 is a reply to message #122248] Wed, 02 May 2007 08:06 Go to previous message
Originally posted by: evaandoli.dodo.com.au
Ben ,
I finally got around to spending too much time on this and came up with the
following solution:-
Look at class (replace YourDiagramDomain with yours)
<YourDiagramDomain>DiagramEditorUtil
It contains a method called:-
createDiagram(
Which itself contains a method called:-
protected CommandResult doExecuteWithResult(
In here you get access to the top level model created.
So you can do somthing like:-
model.setName(modelURI.path());
Anyway that is how I did it,
Stuart
"Ben Renwart" <renwart@lippmann.lu> wrote in message
> Hi everybody,
> benren.
Previous Topic:Opening the Diagram from code
Next Topic:GMF Filename - passing it down to model attribute.
Current Time: Fri Oct 17 06:17:45 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
