| DateTime Widget [message #121406] |
Thu, 12 February 2009 10:13  |
is it possible to navigate with keys in the DateTime Wiget to switch between
day, month and year, for example?
I couldn't figure it out.
Markus
| Re: DateTime Widget [message #121459 is a reply to message #121452] |
Thu, 12 February 2009 12:03   |
Hmmm,
it looks like it is not only the key naviagtion that does not work. I also
can not enter anything!
Is seems that the focus of the widget is not set properly. I navigated to
the widget using the tabulator key.
There is only a dotted border around the widget, but I can not edit anything
or move around using keys.
I tested with IE7 and Firefox 3.0 in the Controls Demo -> DateTime.
Markus
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:gn1esi$2i9$1@build.eclipse.org...
> Hi Markus,
> I've just check it with the Controls Demo -> DateTime tab with SWT.DATE
> style flag. The navigation with arrows keys is working as expected. Which
> browser do you use? OS? Safari? It is known issue that the key handling
> does not work on Safari.
> Best,
> Ivan
> "Markus Kr??????????????????????" wrote:
>> between day, month and year, for example?
>> Regards,
>> Markus
| Re: DateTime Widget [message #121475 is a reply to message #121467] |
Thu, 12 February 2009 12:44  |
I filed Bug No. 264729
news:gn1ljm$kp9$1@build.eclipse.org...
> Hi Markus,
> please file a bugzilla about this issue.
> Ivan
>> Hmmm,
>> also can not enter anything!
>> anything or move around using keys.
>> Regards,
>> Markus
>>> Hi Markus,
>>> Which browser do you use? OS? Safari? It is known issue that the key
>>> handling does not work on Safari.
>>> Best,
>>> Ivan
>>>> Hi,
>>>> Regards,
>>>> Markus
FUDForum. Page generated in 0.04763 seconds
