| OSGI error or something like it [message #120676] |
Tue, 31 January 2006 03:19  |
Originally posted by: jan.tanis.coas.com
Hi all,
Due to my experience with the XML ODA UI I tried to go from scratch.
However, when I deploy my dummy I get the following stacktrace in my log
file:
!SESSION 2006-01-31 09:14:03.240
eclipse.buildId=unknown
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_NL
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 1 2006-01-31 09:14:04.992
!MESSAGE NLS missing message: ReportSettingPageDesc in:
org.eclipse.birt.report.designer.ui.rcp.nls.messages
!ENTRY org.eclipse.osgi 2006-01-31 09:14:30.990
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.birt.report.data.oda.soap.ui (82).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.birt.report.data.oda.soap.ui.UiPlugin for bundle
org.eclipse.birt.report.data.oda.soap.ui is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.birt.report.designer.ui.odadatasource.wizards.Da taSourceSelectionPage.getNextPage(DataSourceSelectionPage.ja va:269)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:747)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.birt.report.designer.ui.actions.NewDataSourceAct ion.run(NewDataSourceAction.java:83)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.birt.report.designer.ui.rcp.DesignerApplication. run(DesignerApplication.java:36)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
... 52 more
Root exception:
Does anyone know what is wrong with it? I remember that Jason said
something about OSGI and plug-ins. But I can't remember what it was.
Best regards, and thanks in advance. Jan.
| Re: OSGI error or something like it [message #122245 is a reply to message #120698] |
Tue, 31 January 2006 19:23   |
Jan,
Did you use "Eclipse -clean" to re-start Eclipse after you deploy/update
your plugin?
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Jan Tanis" <jan.tanis@coas.com> wrote in message
news:drn7hp$afv$1@utils.eclipse.org...
> It seems that BIRT is just ignoring what I define in my plugin.xml. I've
> added a new implementation of DefaultExtendedDataSourceWizard and refer
> to it from my plugin.xml. However, BIRT still calls my old
> implementation. This is just freaking me out. Does somebody know WHY
> BIRT is doing this?
> Thanks, Jan.
> Jan Tanis wrote:
> > Hi all,
> > file:
> > !STACK 0
> > at
> > at
xtImpl.java:965)
> > at
ava:321)
> > at
..java:266)
> > at
assLoader.java:116)
> > at
oader.java:337)
> > at
..java:389)
> > at
..java:350)
> > at
> > at java.lang.ClassLoader.loadClass(Unknown Source)
> > at
..java:275)
> > at
a:227)
> > at
ndle.java:1259)
> > at
> > at
> > at
> > at
leExtension(ConfigurationElementHandle.java:48)
> > at
nPage.getNextPage(DataSourceSelectionPage.java:269)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
tem.java:488)
> > at
tionItem.java:400)
> > at
> > at
> > at
> > at
> > at
> > at
ication.java:36)
> > at
java:226)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
> > at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
> > at java.lang.reflect.Method.invoke(Unknown Source)
> > at
..java:403)
> > at
..java:350)
> > at
> > at
..java:275)
> > at
a:227)
> > at
> > ... 52 more
> > Root exception:
> > at
..java:403)
> > at
..java:350)
> > at
> > at
..java:275)
> > at
a:227)
> > at
> > at
xtImpl.java:965)
> > at
ava:321)
> > at
..java:266)
> > at
assLoader.java:116)
> > at
oader.java:337)
> > at
..java:389)
> > at
..java:350)
> > at
> > at
..java:275)
> > at
a:227)
> > at
ndle.java:1259)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
tem.java:488)
> > at
tionItem.java:400)
> > at
> > at
> > at
> > at
> > at
> > at
ication.java:36)
> > at
java:226)
> > at
> > at
| Re: OSGI error or something like it [message #122442 is a reply to message #122245] |
Wed, 01 February 2006 01:34  |
I'm so stupid! No, I didn't. So now it works. Thanks Gary!
Best regards, Jan.
Gary Xue wrote:
> Jan,
> your plugin?
FUDForum. Page generated in 0.05242 seconds
