Home » Eclipse Projects » Eclipse Platform » Problem with runtime workbench / plugin testing / external jars
Problem with runtime workbench / plugin testing / external jars [message #120490] Tue, 02 September 2003 11:24 Go to next message
Originally posted by: ssr.whitestein.com
I am running Eclipse 2.1.1 on w2k.
I am developing an Eclipse Plugin. I can test it in the runtime
workbench... as long as I don't need anything not included in Eclipse.
Let me clumsily explain:
For access/manipulation to XML files I use JDOM. I can include the
jdom.jar in my Plugin Project, no problem (either with Properties>Build
Path>Add External JARs; or with importing the jar-file as File into the
project and then Properties>Build Path>Add External JARs. I can code
with classes provided by jdom.jar: import statements work, code assist
works, no error marks show up.
When I want to test the plugin in the runtime workbench, it seems that
there the classes from jdom.jar can't be found (I did some simple debug
tests: plugin code which uses jdom imports is just not executed).
Can anybody tell me how I need to correctly set up Eclipse/runtime
workbench so that it can handle "external" jar-files?
Thanks for your help, cheers,
Sascha
Re: Problem with runtime workbench / plugin testing / external jars [message #120660 is a reply to message #120490] Tue, 02 September 2003 16:34 Go to previous messageGo to next message
Originally posted by: jmyron.ioconcepts.com
I'm guessing you need to do two things so the runtime workbench can access
the classes. Put a copy of the jdom jar file in the eclipse plugin directory
for your plugin. Then doubleclick on the project's plugin.xml file in the
package explorer. Click on the runtime tab then add the jdom jar file as a
runtime library.
"Sascha Robert" <ssr@whitestein.com> wrote in message
news:bj2cmc$2gs$1@eclipse.org...
> Hi
> Sascha
Re: Problem with runtime workbench / plugin testing / external jars [message #121757 is a reply to message #120660] Wed, 03 September 2003 04:22 Go to previous message
Hi Myron
Thanks for your help, it worked out.
1. I imported the jar into the Project folder
2. I included it with Properties>Java Build Path>ADD JARs... into the
project
3. I added it to the plugin.xml like this:
<runtime>
<library name="jdom.jar">
<export name="*"/>
</library>
</runtime>
Cheers, Sascha
> runtime library.
>>Hi
>>Sascha
Previous Topic:how to open a MessageDialog from progress monitor run method.
Next Topic:Eclipse and CVS: separability of code ?
Current Time: Sat Oct 25 16:45:17 EDT 2025
Powered by FUDForum. Page generated in 0.03204 seconds
