| Register PespectiveListener [message #120196] |
Fri, 30 January 2009 10:52   |
Eclipse User  |
I would like to register PerspectiveListener an open an editor if a special
perspective becomes activated.
Normally I do this in my Activator.start() method. But I get the
"IllegalStateException" because no context ist available. I also tried it
with UICallBack.runNonUIThreadWithFakeContext() but since this method also
needs a Display I get the same Exception.
Am I doing something wrong? Is there a better place to register my Listener
at where it works better?
Markus
| Re: Register PespectiveListener [message #120283 is a reply to message #120231] |
Tue, 03 February 2009 06:09   |
Eclipse User  |
Hi again,
you could even use an IStartup implementation contributed by an
extension to org.eclipse.ui.startup.
Greets
   Benny
Benjamin Muskalla wrote:
> Hi Markus,
> the entrypoint is the first place which is session-aware for your
> application as the entrypoint implementation is loaded on a per-user base.
> BUT it's not the right place either for a perspective listener. In RCP
> it is common that the workbench is already running when your plugin
> loads. In RAP the workbench is started with the user session and thus
> may not be available immediately. I would suggest to use the workbench
> window advisor do to stuff like that.
> Cheers
>   Benny
> Markus Krüger wrote:
>> Hi Ralf,
>> I think I need 23 listeners, one per workbench/user. Well I guess that
>> you mean that the bundle is only started once, so this is the wrong
>> place to add the listener.
>> But where else can I add it, so that there is one listener per
>> workbench/user?
>> Regards,
>> Markus
>> "Ralf Sternberg" <rsternberg@eclipsesource.com> schrieb im Newsbeitrag
>> news:glvdmf$l7k$1@build.eclipse.org...
>>> Hi Markus,
>>>> special
>>>> tried it
>>>> method also
>>>> Listener
>>> Think again. Let's say you have 23 active users. How many workbench
>>> instances do you have? And how many active bundles? How many of those
>>> listeners do you need?
>>> Ralf
FUDForum. Page generated in 0.31956 seconds
